Guest vhpacer73 Posted September 19, 2005 Share Posted September 19, 2005 What adjustments would need to made to the engine (toyota 4k) when using avgas?(off-road use) I just put a head on it with an 11:1 comp ratio. So yeh I spose timing?? And what else??? Thanks Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted September 20, 2005 Share Posted September 20, 2005 i'd check the fuel lines.. the only reason i say is cause i had a look at my corolla (87 model with 4k) and all the lines are cracked to sh!t Quote Link to comment Share on other sites More sharing options...
durty Posted September 20, 2005 Share Posted September 20, 2005 same with the ones in my starlet. absolutely fux0red Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted September 20, 2005 Share Posted September 20, 2005 yeah just the timing prolly take it up to 12-15 degs . is it just a stock head thats been planed down heaps or has it got other mods aswell? Quote Link to comment Share on other sites More sharing options...
Guest vhpacer73 Posted September 21, 2005 Share Posted September 21, 2005 Yeh thanks.Yep its just a standard head been planed a couple of mm. I know it has an 11:1 comp ratio. The motor has a jetted 32/36 webber and a lumpy cam. It used to have a heavily ported head but I found out that it was actually robbing the motor of power, because it was ported for a much more powerful engine. Will running it on av (or mostly av) just lead to engine troubles in the future? Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted September 22, 2005 Share Posted September 22, 2005 only if ya get pulled by the cops on an older engine av is prolly better cause it has lead in it which lubes the valve stems and guides and stops valve seat recession which is the wearing out of the valve seat cause unleaded is dry and the valves rotate when the engine is running. 4ks have an alloy head anyway so you wont have that prob cause they have hardened valve seats. Quote Link to comment Share on other sites More sharing options...
Guest vhpacer73 Posted September 22, 2005 Share Posted September 22, 2005 O sweet cheers man. This sites very helpful Quote Link to comment Share on other sites More sharing options...
TygerTung Posted September 22, 2005 Share Posted September 22, 2005 You'll also want to fit twin sidedraughts or you will just be wasting your time, the only way to get any real power out of these engines is with twin sidedraughts Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted September 22, 2005 Share Posted September 22, 2005 You'll also want to fit twin sidedraughts or you will just be wasting your time, the only way to get any real power out of these engines is with twin sidedraughts or a big fuckin hairdryer the only prob with av is that ya cant roll up to the place that sells it and fill ya beast up, UNLESS.. make some plywood wings up and try and convince the seller its an areoplane . ive been experimenting with 98 with nulon octane boost for the corty as it also has too much comp 4 pump gas . this combo works well and feels pretty much the same as av can even keep my 17deg timing the same. have to go to 10deg on 96 then it wont start or idle properly. can go 12-15 on 98 better but still feels a bit flat. Quote Link to comment Share on other sites More sharing options...
esky boi Posted September 22, 2005 Share Posted September 22, 2005 or a big fuckin hairdryer the only prob with av is that ya cant roll up to the place that sells it and fill ya beast up, UNLESS.. make some plywood wings up and try and convince the seller its an areoplane . ive been experimenting with 98 with nulon octane boost for the corty as it also has too much comp 4 pump gas . this combo works well and feels pretty much the same as av can even keep my 17deg timing the same. have to go to 10deg on 96 then it wont start or idle properly. can go 12-15 on 98 better but still feels a bit flat. Dam thats alot of advance.. how high is your comp ratio again? Quote Link to comment Share on other sites More sharing options...
Hemi Posted September 22, 2005 Share Posted September 22, 2005 get methanol it would be antiknock additive if the company that made the tetra lead one didnt do something about it , and its cheap if u know where to go Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted September 23, 2005 Share Posted September 23, 2005 its about 10.7-1 but i have a 310dur cam so the engine bleeds comp until about 2500rpm because the inlet and exhaust valves overlap so much. theres less chance of detonation after 3-4000 because the engine is free reving and not loaded right up. because my engine is basically a race item i am more concerned about total advance not static advance. i set it up at 2500rpm to 38deg total which is heaps for a chevy. which works out at about 17deg static Quote Link to comment Share on other sites More sharing options...
Ned Posted September 23, 2005 Share Posted September 23, 2005 ya cant roll up to the place that sells it and fill ya beast up yes you can anyways. i take it you have an aftermarket exhaust...? without a catalyc converter (i know i cant spell) i hope.... because those things dont like av gas. if you want av gas, just go to BP kumeu, talk to jeff AND ONLY JEFF!!! and tell him Neil that used to work there send you and ask if you can get some av gas. he might ask you to come back on a different day, but i'm pretty sure he'll let you get some. but then again, i take it you are getting it at mates rates... because if you have to pay full price (~$1.90) then its NOT worth it. as you get ALOT LESS mileage out of avvy then 98 Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted September 23, 2005 Share Posted September 23, 2005 hey thanx for the heads up bro , but im not about to drive 500kms just to buy avgas. ill just drive the 8 kms to the aerodrome and fill up a couple of 20s for $1.60 lt. hey and my cars pure oldschool bra there are no mod cons and certinly no cats in my exhaust cept for the occasional one i might run over haha Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted September 24, 2005 Share Posted September 24, 2005 $1.60... thats cheaper than regular petrol! what a great excuse to run it Quote Link to comment Share on other sites More sharing options...
Ned Posted September 25, 2005 Share Posted September 25, 2005 only just! and unless you tune your car to run on it properly, youll get fuck all more power out of it. and as i said before, it gets way shitter milage! Quote Link to comment Share on other sites More sharing options...
phillip@premierauto.co.nz Posted September 25, 2005 Share Posted September 25, 2005 i can sell you a 20ltr drum of RACE fuel for $36.00 inc, wich is also got lead in it, legally can be used on the road because you paying gst. Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted September 26, 2005 Share Posted September 26, 2005 DELETED Quote Link to comment Share on other sites More sharing options...
davidian Posted September 26, 2005 Share Posted September 26, 2005 burn! Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted September 26, 2005 Share Posted September 26, 2005 i can sell you a 20ltr drum of RACE fuel for $36.00 inc, wich is also got lead in it, legally can be used on the road because you paying gst. what brand is it do u have it on pump? Quote Link to comment Share on other sites More sharing options...
