droppdkp Posted July 25, 2005 Share Posted July 25, 2005 Hey where or how should i go about rolling guards. I've heard some pretty bogan ways about using exhaust pipe and reversing, but looking for other options. Anyone here done it? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted July 25, 2005 Share Posted July 25, 2005 panelbeaters mang, go talk to some or something and get ideas from them/pricing... Quote Link to comment Share on other sites More sharing options...
davidian Posted July 25, 2005 Share Posted July 25, 2005 how handy are you with the hammer? sounds rangi as fuk but works well: hammer the inside lip out as much as you can, should leave you with a wavy guard pushed out.. then just bog up the arch and spend time re-bogging it and sanding, mine came out nicely Quote Link to comment Share on other sites More sharing options...
4D105e Posted July 25, 2005 Share Posted July 25, 2005 i havent done it but i hear ya cu slits on your inside lip and bend it out once it is all out you use a wooden baseball bat and a hammer to beat it basically into shape then insert a aluminium strip around the outside pot rivet it and bog once again pritty horry but hey Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted July 25, 2005 Share Posted July 25, 2005 i think you can go to places and they can rolled your guards no paint and no panel work enlarge pic it moves Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted July 25, 2005 Share Posted July 25, 2005 Another option to fit larger mags is to flare to guards. This usually involves lots of cutting and welding like below. The end result looks great Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 25, 2005 Share Posted July 25, 2005 I got a panel beater to slice the gaurd and add metal cause i found normal rolling wasnt enough. Thats gay mk1 front gaurds tho Quote Link to comment Share on other sites More sharing options...
Ned Posted July 25, 2005 Share Posted July 25, 2005 enlarge pic it moves hihihi, cool i'm getting my pannel beater in whenuapai to do my lips. $100 i think he said its slammed customs next to whenuapai BP. as in right next to it, same building (left side) Quote Link to comment Share on other sites More sharing options...
droppdkp Posted July 26, 2005 Author Share Posted July 26, 2005 $100 sounds alrite, im guna ring round now find out. Sisters boyfriend is a mechanic and he reckned around 150 and i kno a guy who got them proffessionally done for 50 at mates rates. Quote Link to comment Share on other sites More sharing options...
droppdkp Posted July 26, 2005 Author Share Posted July 26, 2005 I'v got a phone quote of about $100 for both the back guards from Castle panel beaters, but all the ones i rang said bring it in first, so will do 2moro. Quote Link to comment Share on other sites More sharing options...
droppdkp Posted July 27, 2005 Author Share Posted July 27, 2005 Found a place thats gonna do it 4 $45 a guard in henderson. The guy was real choice and thought my car was pretty mint for its age, and was telling me about his sons turbo 79 rolla wagon and even asked me to pop the hood so he could see my 4k. Quote Link to comment Share on other sites More sharing options...
oLdSkOoL1 Posted July 27, 2005 Share Posted July 27, 2005 I Just used a hammer to smash the lip dwn aye all g Quote Link to comment Share on other sites More sharing options...
Guest Demonmk2 Posted July 27, 2005 Share Posted July 27, 2005 yeah i just got the old hammer and dolley and did it that way :S just make sure if ur using the dolley and doing it from underneath u dont drop the dolley on ur head as it kinda hurts Quote Link to comment Share on other sites More sharing options...
Defcon Posted July 27, 2005 Share Posted July 27, 2005 This is how i rolled my guards. I made sure i had loose wheel nuts then went for a drive, some where along the line the wheel will come off and jam between your guard and the road, because you going 50+ k's an hour whe wheel still spins and hence rolls your guard. Be carefull to have the right sized rim tho, cause if tis to small, you will just end up damaging your lower control arm. Lucky for me i had the rim calculations correct. Def' Quote Link to comment Share on other sites More sharing options...
droppdkp Posted July 27, 2005 Author Share Posted July 27, 2005 Puttin off the guards for now till i sort out my mags cause they're playing up, so now im riding on 155 Quote Link to comment Share on other sites More sharing options...
lowlancer Posted July 27, 2005 Share Posted July 27, 2005 Buy my rims:P Quote Link to comment Share on other sites More sharing options...
Bistro Posted July 27, 2005 Share Posted July 27, 2005 This is how i rolled my guards. I made sure i had loose wheel nuts then went for a drive, some where along the line the wheel will come off and jam between your guard and the road, because you going 50+ k's an hour whe wheel still spins and hence rolls your guard. Be carefull to have the right sized rim tho, cause if tis to small, you will just end up damaging your lower control arm.Lucky for me i had the rim calculations correct. Def' That happened to a mates BMW at `100k. His 17 past him adn jumped into a paddock. Ripped the guard in half pretty much, like ripped up the middle and all bent back. So lol. Quote Link to comment Share on other sites More sharing options...
solidstripe Posted July 27, 2005 Share Posted July 27, 2005 Yeah, just pay the $50 or so for each guard to be done by a pro. That way when you damage the outside of the guard you don't have to pay for bog, sandpaper, time, primer, paint etc... Quote Link to comment Share on other sites More sharing options...
davidian Posted July 27, 2005 Share Posted July 27, 2005 Found a place thats gonna do it 4 $45 a guard in henderson. The guy was real choice and thought my car was pretty mint for its age, and was telling me about his sons turbo 79 rolla wagon and even asked me to pop the hood so he could see my 4k. care to share: Quote Link to comment Share on other sites More sharing options...
droppdkp Posted July 28, 2005 Author Share Posted July 28, 2005 Wat did ya wana kno? The place is next to firestone on moselle ave, forgot wat its called but has a big panel and paint sign. Quote Link to comment Share on other sites More sharing options...
