oLdSkOoL1
oLdSkOoL1's Achievements
Advanced Member
Advanced Member (3/5)
0
  1. I Just used a hammer to smash the lip dwn aye all g
  2. oLdSkOoL1
    warants
    I have superlow lovells. the ride is so fukin hard bounces all over the place and its about 75mm off the ground at the chassis rails
  3. That is a very nice engine you have there mate
  4. cheers guys ill ring the auto elecs tomorro and see what they think, datsunboy ill pm u if I need an ecu. cheers
  5. Im looking at buying an oldskool Skyline with the L20ET engine, but there is something wrong with the injectors or computer, when the battery is connected the injectors start pumping gas even with the keys are out of the ignition . What could be causing this?
  6. im gunna make a panel with like 10 switches on it like the 3 way switches and have them all wired up randomly so you have to know which switch goes up or down etc
  7. id go with injection bro, then you can run I/C and a BOV
  8. 18rg with the alloy yamaha head they go hard dnt get the shitty low comp one tho
  9. oLdSkOoL1
    escort guards
    could well be welded on as my mk1 guards were welded, just get out the angle grinder
  10. primer also sucks up water like a sponge
  11. im fixing up my 73 Mitsi GTO colt, lots of rust to fix, flares, mags and new paint, it has 4 into 2 extractors into 2 1/2 inch pipe, single muffler near the diff then 2 3/4 out the back, hopefully getting the cam modified and some twin 41mm dellorto sidedraft.
  12. Droppin a 350 chevy into a 80s Range rover I WISH
  13. i got some air shocks on a stock mk2 diff with leafs if anyone wants to buy it $80
