Everything posted by Alfashark
Being a lazy bugger, I haven't checked your progress thread but when you pulled the pump/accumulator out, did everything go back exactly how it was to start with? Possible you dislodged some crap and it went into the line post accumulator which could be starving supply at the metering head?
Lush! Old enough to be terribly British, young enough to still have reasonable access to parts. Looking to EFI convert, or just bring the K-Jet up to scratch? If you can get past the usual Barry-bodges made by the uninformed, K-Jet does a pretty good job really.
Possibly old moulds that Italeri have acquired from somewhere. Not car related, but I got my hands on an ancient Frog 1/72 Beaufighter kit a long time ago. The moulds were past their best by the time that kit rolled off the line, and it took a lot of work to bring it up to scratch... Fast forward 5 years and one of the no-name brands that popped up in the mid 2000s released a Beaufighter kit clearly made from the same moulds as the Frog kit had been nearly 50 years earlier - Same flaws in the same places, but magnified further by the extra age.
Diff - building in then measuring 'toe in' in a live axle.
Alfashark replied to johnny.race's topic in Tech Talk
Try and find someone involved with the Mainland Muscle Car series - I remember from my long nights working in a servo, I read a bit in Aussie Muscle Car mag about how the various teams in the 70s in the Aussie Touring Car champs would tweak live axles using the methods Adoom mentioned above. -
Yes. The Fabia, in 180,000km and 12 years of ownership has cost about $1500 for the 12 routine oil+ filter services required by the manual in that time. Maybe another $200 for the cam belt and water pump.
Define small. http://www.exidebatteries.co.nz/battery-range/passenger/Endurance Have a look at that list and check each one's spec out for CCA vs Dimensions. A DIN55 is a smallish battery in my books - 175H x 175W x 242L.
A mate had one and was convinced that both the VS and his VN were around the 2T mark... He quickly ran out of places to attack with a hole-saw in the pursuit of weight reduction. And achieved fuck all in the process.
Did you mean a VS Ute? Because there's no way they're more than 1600-1700kg unless you're lugging a spare boat anchor or two around on the back, given a VS V8 sedan tipped the scales at a bees dick under 1500kg
As long as it doesn't go straight to the spam folder, there's a good chance someone will know something or someone who does - I got curious about the dealership that sold my Golf in South Africa. The dealership still exists, the saleswoman had retired not long ago but the receptionist forwarded my email on to her and we had email sharns as she remembered the original owners and was pleasantly surprised to hear they were still alive and well here on the other side of the world and in their nineties.
How wide is the useable area of the engine bay in one of these?
- 39 replies
- oil leaks
- poor brakes
(and 4 more)
Tagged with:
I thought of you today KK - There was a white Prius in Hamilton at a suitable level of low with some wheels very similar to yours in a gunmetal shade.
Normally have the injector seats machined out to suit modern injectors. @00quattro00 might be able to advise further.
Lol. Unless your mate is going to the effort of putting a cold air box around that filter, he's going to lose power. It may sound a bit throatier, but no performance gains to be had in that application.
Mint! Thanks lads. I'll finish cleaning the bastard thing out and then get to applying some snot.
Never used paper gaskets from the factory, just alloy on alloy.
Righto lads, what the preferred breed of sealant/snot for an inlet manifold -> spacer -> carb assembly?
Probably from the same voices in his head that tell him that anything less than max factory height is a mortal sin. Wet-clutch DSG units require a fluid change every 60,000km and have a very clearly documented drain/refill setup. Dry-clutch DSGs were designed as a filled for life unit, but received the wrong oil from the factory - global recall and refill via the drain and refill ports...
Familiar with any workshops who may be prepared to loan you their brake meter for a box of beer?
Also, when I had my CGT, some genius had played around with the K-Jet setup so it ran like a bag of dicks - I persevered and got it back to a healthy state, but I did a bit of research into converting it to carb and Holley had a carb+manifold available as a kit at the time, maybe 2009/10.
Load and cycle dependant - The battery in my Golf is good for 2 years between charges, then just whack it on the Ctek overnight and it's good to go for another 2 years. No clock, no stereo, no alarm. Only gets started to move it out of the garage if I need access to the shit stored behind it.
Pick-A-Part? Takes about a minute to grab each element...
Eh? I mean he just removed the factory upholstery from the seats, yoinked the elements out and stuck them down onto the foam in his existing seats. Ran them off a rotary 4 position switch.
