Chipping away, nearly finished.
Lots of little bits done.
Mud flaps, half done tail lights, safety chain, decent pins for each end of the ram, most of the table top welded on, and a hydraulic tank that was a LPG cylinder.
The tank was quite a bit of work, It has a removable top so I could get inside it and clean and paint it inside so no grit or welding splatter goes through the pump. It also mounts the return filter. If I did it again I'd do it a bit differently. So it goes.
Everything's plumbed up, pump is mounted and it works!
Well even.
There's a couple of things to do yet, the Chinese ram has a pin hole in a weld and leaks oil, there's a couple of braces and guards to make, and wire up some tail lights. Then it's all go.
