hop
Everything posted by hop
Before you go balls deep and wire up sensors etc there are special paints you can apply to the disc and it will change colour when you reach that temperature. I am not sure where you source it but we used to have three different patches (600 700 800 degree C or whatever) on the disc and you can quickly see where the temp got to.
Cheers for the link will come in handy. Have another Q. I see these engines need 62 psi Fuel rail pressure, which pump did you end up using? 044?
I have been following this thread and I like what I see! Reading through the discussion now I see you guys talked about the ecu / wiring alot. I have just picked up a dual vvti 3sge, Factory manual etc. I am not afraid of the wiring but I would like the keep the std ecu for the time being, do you think you could point me in the right direction for pin outs diagrams etc. Obviously the ones you found are good! Cheers. Also can I run it without the standard instrument cluster attached!?
How did people 4age before SQ?
Saw this at my mates wedding couple weeks back A+++! Cheers! Tough as guts! Even got one of the old boys yarning bout the good ole days,one of them may have mentioned something about carrying a can of nails on his motorbike to disperse the fuzz lol@!
Check the PCV is functioning as it should
Sweet will try and get this underway! After looking at a few videos im hoping the better spray pattern and the injectors being 20 years newer will make a difference
Not a big poster but got a question rolling around atm. Upgrading to new style injectors on a megasquirted project, lower plenum and fuel rails all have enough meat to bore out. Old style injectors have a 11mm oring new bosch ev14's have 14mm both ends, What size should I be drilling the bosses to ensure a good seal? 13.9 13.5? Is there a rule of thumb? Also mentioned it to a workmate he said it would be best practice to do it with an end mill because a drill bit will create a tapered hole, is this correct?
Hey, nice to see a pic of Sanatorium Hill. I live around there. Very cool roads
Hey, I have had an issue with an earlier pioneer amp (the model before this?) where the RCA connectors were not getting earth. Try connecting the exterior of one the RCA's that you are not using to earth. That worked for me.
Hey man im digging this! Just wondering what gearbox options you know of for the m62? Also what software are you using to reprogram the DME? Cheers
Dude iv seen some weird shit on oldschool but that gearknob takes the cake.
wannabe's salon (SW20) and smoking lounge (GS131) of nein style
hop replied to wannabe's topic in Other Projects
cool sw20s man. I have one myself with a 3vzfe I fitted recently. Hey one thing that caught my eye was that cage. Is that a bolt in item? Havent seen a bolt in one before -
Dude that is a score! These bikes kick ass! 18 thousand 5 hundred REDLINE! and quad CV carbs! A friend has one and it is definitely faster than my GSXR250 of the same vintage.
This looks tough! Always loved the Sapporo shape
Yep, as far as I know its the standard for reworking. Should be readily available. The 1.6 we use has a zinc coating too.
1.6mm Panel steel?
This is awesome! Cant wait to hear it come down the road man! il be listening out! Also if you need a hand today yell out
That sure is a clean C1! Im diggin the megasquirt too.
Ling's Silver Grand Father ---- Plan B (NOT a SPAM THREAD)
hop replied to LingLing's topic in Project Discussion
I have see this car around Hamilton and it is indeed a looker. Good luck with everything. -
Hops 1984 Isuzu piazza- complete with fluffy cat
hop replied to yoeddynz's topic in Project Discussion
Right I got the engine all wired up to the std ecu. Had a bit of a play around and has good cranking power a massive spark and was getting the fuel. Cranked it a couple of times and lost spark? When I took the coil lead off to check it was arcing 3-4cm to the rocking cover. Went to crank again and nothing. Cant get it back, will go over everything tomorrow. Looking forward to getting this beast going. Was rocking the front suspension just cranking it! -
Mate this is sweet! Gotta love how those brakes fill up the front!
Found it on the side of the road in Tamahere. -
Right bout time I update, sorry for large images my usual upload is not working atm Got the engine to work with the 4zc1 sump. 4jb1 gasket is what I used I think I have the 4Ze1 mounted and attached to the 5 speed. I was suprised that the flywheel cleared as it is significantly bigger than the g200 equiv. Everything bolts up as if it was a g series. Lets see how strong this pup is. Engine is sitting in the exact same place as the g200 however the 4z is a shorter motor and sits further into the engine bay. Issues Dizzy is in a different spot and is fouling where the heater lines come through firewall. Id like to keep the heater. One line is copper and can be detached from behind the firewall so this is no problem however the 2nd line is plastic and seems to be a part of the heater box itself. If I cut the plastic back is there a way I can flare it again? Power steering pump is on the other side on 4z. Will need custom line made up for the high pressure flow. Water outlet on the manifold fouls the master cyl just enough that I will not be able to get the hose over it. Could it be a as simple as heating and bending out? Waterpump hardline fouls everything! Will need a new one made up to go from the block to radiator bottom.
Ok so iv got alot of time on my hands atm Decided that this has to be done. Using g200 mounts and a 4zc1 (turbo) sump I can get the 4ze1 to sit pretty well, If you have a look up the page it sits in almost exactly the same place but the deck height is higher. I will need a custom plenum by the looks of it. The bottom water hardline is fouling on the crossmember but thats the only prob this side. On the other side my mount is fouling the oil filter and beause the dizzy is at the back of the head on the intake side it will be a tight fit too. Cheers
