Everything posted by HighLUX
98cc's Resurrection Of The "Smith Spider" 2 stroke race car--Now with SOUND
HighLUX replied to 98cc's topic in Other Projects
Fuuuuu so much want for a hillbilly 2 stroke trucker cap -
Nah man none of those bits left. They all seem to be crown failure points, if had so many people as me for those same bits
Brown interior. None of the sc’d crowns came manual I pretty sure. Gotta use parts off a povo 130 wagon
I still have one of this im wrecking. Lots of interior bits left
The low seat height in a hiace of that era can be a cunt if you try to fit any sorta late model 4 cylinder without major work to move the engine more rearwards. A 3Y-E from a Townace van would fit with some minor work to move the throttle body which would give you an injected 2L petrol engine
More tutu'ing and getting better results. Whipped the head off to check squish clearance after everthing had settled, piston crown still had the faintest mark on the back edge where its just contacting when things expand. Very cautious grind with the die grinder to fix the touching and slapped it back together. Went up to a 120mj jet again an dropped to a 48 pilot which is seems very happy with, enough torque to hold 4th up most hills if I keep it on pipe and the high rev off idle cutout/splutter has gone with the smaller pilot jet. Just went for a happy backroad nang and it will rev right out to the top of 5th on the flat now which is about 78-80ks at 10k RPM.
Any yamaha dealership that sells dirtbikes should have it, failing that try somewhere that sells Yamaha jetskis
I do like a good Bj And I still lol at how much steering input vs how much steering reaction this thing gets
Your uber driver Chris is on his way
Just ordered a 13T sprocket from the UK to try get a bit more top speed without too much torque loss that I got from the 15T one and another Giannelli spanny/muffler combo to suit a TS50 instead of the TS80 one im currently running. It will be interesting to see how the power band changes. I slapped the factory exhaust back on for lols and it makes the bike so lazy, no noticeable powerband just quiet nangs
Im curious as to what sorta lexus 6 speed is now behind the 1725. Is it one from an altezza with some sorta flash linkage setup to get most the gears working?
Oh lols. The needle had popped the clip up when I put the carb back together earlier so it was just jumping round doing its own thing. Got it sorted and happy idle/shed nangs again. Seems alot more rev happy now too. Will wait for daylight tomorrow for more test n tune
2 steps forward one step back it seems. Swapped base gasket out to 1 I barry’d up with a ball peen hamer out of 1.2mm gasket paper. Success as can now run 1 headgasket and head with untouched squish band without piston touching the head issues. Got excited for a test nang but now its running like shit and wont idle/lazy to rev. Spark plug is super wet almost dripping with fuel now. Gave up for the day and will check the carb tomorrow/drop a jet size
Lols I could see curious looks in the rear view mirror of a cop I was following when taking the TS to work one morning. He changed lanes and slowed down a bit thought here we go so passed him gave him a thumbs up, must of seen my rego tag and number plate then got a thumbs up back and nanged on my merry way
The answer is forced induction
Signs under the crown?
Nope supposed to be bolt on TS50 big block kit. Im tempted to try make a base gasket out of 1.2mm gasket paper instead of 0.6mm that came with the kit. Might fuck with port timing a bit but better than blowing it up
Piston hits the head without taking a bit off the edge of the squish band
Voltage sensing relay? VSR?
Yeah VHT wrinkle black and then oven cure it yourself is the best bet. Might take a couple of goes to get it looking perfect but still cheaper than sending it to the man
Reeds seem fine but dunno what im looking at other than they seal against the reed block ok
Carboning up on the exhaust side. Its had a 118mj in it when it popped on the way to east cape ride
Done 75ks in the last couple of days so whipped the head off to check out whats happening with compustion. As you can see its got the same issue of only burning on the front of the combustion chamber still with the new tutu'd with head. I thought the electrode for the plug being in the way was not helping the cause but they are 180 out on the 2 heads and still no difference. Time to get it booked in at @MopedNZ work the 2T wizards to sort it properly
Yeah I noticed the head likes to move as you torque the studs up.
Tutu’d with measuring the squish band then pussyed out on taking too much off the head so slapped it back together with 2 headgaskets and some copper spray so no clearance issues and half pie squish band. Removed the oiling barb from the head and jb welded the port up. Running good enough for me to nang round the farm/backroads for now. Might take it to the pakeha to get the squish band clearanced properly after the holidays
