phtmbl
Everything posted by phtmbl
The passengers rail has an feature that with the standard seat when you pull the fold lever, it releases the locking mech on the rails so the seat slides forward. If you are not using a standard seat you will need to adapt a folding system if you want one.
I will have a look through the ones I have, do you want it to use the folding feature of the rail?
Are you after the other half to the rail you have? or are you after the two rails for one seat or a pair of rails (two seats)?
check your universal joints on your drive shaft, they do not normally develop issuse over night but it is common for you not to feel them until they are stuffed
do not forget to take off one of the battery leads if you have not already
Could also be a universal joint on the drive shaft.
i know you want an all in one system, this is exactly what i have at home if you can not find what you are looking for http://www.trademe.co.nz/motors/car-parts-accessories/mitsubishi/interior/auction-532140317.htm
i have prob got a spare oil presure and temp gauge set up from the gto if you want one (electric type)
this may not be of any use but my car does the same on the right hand side some times it appears that the screw that holds the light in also acts as a second earth try turning the indicator on an undoing and doing up the indicatore screws if it has any.
from what i can remember back when we were running aroung in the model before that one with the same engine that was getting real high kpl, 10 liter would get us at least 130k
as said above it is an ecu issue or leaky injectors, we would pop the bonnet and pull out the relay wind over to clear the fuel put relay in and it would start, if it is running fine when it does run dont bother with plugs spend the $$$ on testign injectors
They are not quite universal the early webbers and the delhortos have different placement of the idle stop/set screw where the linkage sits, if you are using newer webbers they are the same. Depending on your tuning and set up skills, and if you know what you are doing it appears to make no differance if you use the stock ballancing set up or take it off and use the universal kit to set up the ballancing.
dot 5 is ok but the only real advantage is that freezing point of it, if you want to upgrade your fluid imo it would be better to go to 4.1, i have no idea if it dose anything to the rubbers in an old car and would love to hear if anyone knows anything more about this.
Thats good to hear, the people who were not happy with them were mecanhics and a tire shop. Maybe i will send the GF's curbed rim there.
i have had many people here in pram say bad things about rim right, one being that they have a bad turn around time.
you could use a 4g52, same size, same gear box size and same mounts but are chain driven. Or you could go 4g51 which again bolt up the same and are old school chain drive.
i can promise anything but try this guy on trade me has a lot of old parts and i mean lots: http://www.trademe.co.nz/Members/Listin ... ber=406686
could it be your auto choke playing up? try pushing you foot to the floor once take foot of gas and turn the key? this can set the auto choke to work.
4NR Jamboree - 25th March - Manfeild/Feilding
phtmbl replied to Sparkle's topic in Lower North Island Region
looked great guys, am gutted i could not make it up. Well done. -
will be heading up from pram if the weather is sweet, anyone heading up from welly and want to convoy? -
will be up your way on sat if you want me to come have a look you should have my number mid afternoon would be good.
hey i was in the nats at auckland and if you need another car for palmy i can also attend. -
Hey dude i am coming up that way to the burnouts in levin, do you want me to stop in and have a look, 021465867 flick me your address
are you home tomorrow? i can come up and look at it for you. i am away all next week so will have to be this weekend.
AKL-RotoVegas Saturday and AKL-Whangarei Sun move stuff?
phtmbl replied to P_Star's topic in Upper North Island Region
Are you going through hams? could you drop something off for me in rotorua?
