Everything posted by tortron
Level sender, oil heater?
Bearded Baldy's 1985 Mitsi L200 Discussion Thread
tortron replied to Bearded Baldy's topic in Project Discussion
yeah mine was out by about that for 20 years from when it was certed these were sold as dodge ram 50's / d50s in the states. so cheap parts off rock auto www.mightyram50.net if you haven't seen it yet -
is it anodised aluminium? some oven cleaner will strip the black off
- 67 replies
- ebike
- vintage bicycle
(and 1 more)
Tagged with:
Pretty much. I put a 2nd gen LSD in mine, it's 4.22 but suits me. Starion ones fit -
now im kinda disappointed you didnt go for some retro fisher and paykel service van logos haha
- 138 replies
never had an issue with using them on a grinder. even on big long panels.
wire cup brush on a grinder would be my go to
some "pros" used to (and some still do) just spray the whole lot and sand to shape. i guess they figure its easier than hammering the few trouble spots, i.e ive mixed this paint already may as well use it/
You might cut that tube and solder a dowel inside to bring the strength back?
Tortron's 3.8 Mayte fair dinkum Mitsi Ute
tortron replied to Threeonthetree's topic in Project Discussion
unless you wanna cut all the cab mounts out for me -
honestly i have already replaced at least 50% of this cab. theres no more original mitsi rust left (im sure theres some in the lower rad support but meh thats easy). if i had sandblasted/dipped this cab when i first got it id be all over a different one, but i think im on top of it now -
80's mitsi colour stripes rad
- 138 replies
would this for example apply to a nurse's private car needed to get to work?
in my experience paint stripper removes the paint in layers, expecially the weaker stuff. my ute tray took 6 applications where it had been resprayed several times. very frustrating for me, potentially great for you
could try one of those sticker remover wheels that go on a drill. basically a claybar?
repco has them
woops saw you tried thinners probably if you let it soak in, wet sheet, cover in plastic?
il do it if theres no one local, send to me with return postage
steel? weld it. i suppose you could fill with jb weld or similar
Quite liking the missmatched panel paintjob
Put this all back together and drove it outside then turned it around and put it back in the shed and cut the other side apart Owning a mitsubishi is so good. recommend it to everyone -
Put the 5m back in and have the same issue
can i interest you in some other worthless shit tho?
i have some period correct indicator/side lamp units if you want em
