Everything posted by peteretep
Russell's Mk1 Cortina_Discussion
peteretep replied to My name is Russell's topic in Project Discussion
hey man, I made a new handbrake cable holder thingy for my escort. First I tried making one out of a thick bit of rubber, but if fell apart quick as the rubber wasn't flexible enough, so new one is made from 3 or 4 layers or thin rubber, Its been on the car for a few years now and its sweet as. Got the rubber from para rubber from memory -
Surely there are some tests you can do to see where a problem might be? Take it out of the car and bench test it with other known good components Or at least you could contact them and ask
There’s something wrong if it takes that long
give this dude a call if you want, I think his name is Peter. He did some digging at my place and has a trailer. 021518901
Oh asses it’s not behaving itself Theres too many pages to read here, is this about an sw20 or is it about an Aston Martin?
The tablet is legit in my car, its not been a problem. Looking at reviews on other tablets yesterday though, it looks like some do suffer from poor brightness or too much reflection, so probably worth considering when looking I'm not sure a windows tablet and tunerstudio would be any good tbh, its hard enough fiddling with a laptop in a car, and you have a trackpad, using a tablet with a mouse sounds horrible
Tuner studio had shadow dash, but I haven’t looked into it yet
well thats interesting, android tablets have moved backwards since 2013, so I guess I will keep my nexus https://www.gsmarena.com/compare.php3?idPhone1=5600&idPhone2=7880
found a couple cool bits of info for bluetooth into microsquirt http://forums.turbobricks.com/showthread.php?t=323337 http://www.instructables.com/id/AT-command-mode-of-HC-05-Bluetooth-module/ Can squeeze a bluetooth module inside the microsquirt
OK, so no one has advice for tablet or apps @yoeddynz I will look into the bluetooth thing, but my msdroid would just crap the bed all the time and was unusable, especially if I added a non-standard gauge. I will do some more research on the other megasquirt apps
Do any of you guys use an android tablet/an app for reading the mega squirt as a removable in car dash? I have a 2014 nexus 7 and used msdroid in the past, but msdroid became super flaky and the nexus seems real slow these days. considering selling the nexus and getting a newer tablet/ also considering new software
awesome man
Nah, doesn't seem to be a file for that, you can add it though! If you are unable to draw the part yourself but have the dimensions, I can draw it up for you for laser cutting etc
I have taken the access panel off my mk1 escort fuel tank, and it was in surprisingly good condition. At any rate, it was just a bit of cork, wouldn't be too hard to make one yourself
make sure nothing is blocked, need to blow everything out. And there is nothing in the tank that could float/move around and get picked up every so often? Next time it happens, turn the car off for a few minutes and start it again, see if it goes away for a while
peteretep replied to h4nd's topic in Other Projects
can you show us how to use them in a video -
I have 1cover insurance at the moment, they seem pretty good and answer questions pretty quick. I have a claim with them at the moment and doesnt seem to be too hard Don't forget to go to a gun shop too in vegas, we saw people walking out with machine guns for rent. Free, but amazing Also, if you can find one, try to check out an old car wrecker, we saw a couple in the desert's, so much sweet old stuff to look at, and more or less free And if you are going to drive, try not to spend all the time on the interstate, if you have time, try drive on some more local roads, lower speed limit so you go slower, but gives you an opportunity to see way better stuff/'real america'
after looking at cars to buy in USA, there is no way I would buy a repaired or body modified car from the states. We looked at some hydro'd cars, holy shit that stuff was crazy. One guy told us he thought the car would break apart above 100kph as he was trying to sell us the car in 'good condition, just needs a little TLC'
well OK then, Once @Roman gets his 3D printer up and running, im expecting to see a new head capable of this
do you know what modern cars afr/timing tables look like? could also be a good comparison In my mind, some modern cars are running like 18:1 at cruise or even leaner. No basis as to where I got that info from though
nah, I got a custom engine mount made from urethane
from memory, one of my mounts was extended 10mm and angled about 12 degrees
Ah yeah you will need special/different mounts then. Slightly longer and slightly angles to match the original face. If you had some thick steel lying around, like 10mm, you may be able to make up a spacer too
