Everything posted by UTERUS
Te Urewera Undertaking, 2019 Nov 29th, 30th, Dec 1st.
UTERUS replied to johnnyfive's topic in Upper North Island Region
- 895 replies
- 17
ORDER CORN -
Anderson is common in industry. https://www.jaycar.co.nz/anderson-35a-sbs-mini-connector-grey/p/PT4484
I'm keen but I just can't swing the day off.
- 26 replies
- bigbusiness
- cbd
(and 5 more)
Tagged with:
Fuck, @Nedand I want to go but realistically it would need to be weekend.
- 26 replies
- bigbusiness
- cbd
(and 5 more)
Tagged with:
Defender has a roverised Dana 60
@johnny.race have you played with Dana 60 units?
Na, just gonna cable tie the UE boom somewhere. -
Bone stock CT110, might do an oil change the night before. -
Ok so for years i've been wondering why tractor pullers take so long to build rpm and boost, and only just thought to google it. Sorry if this is really obvious to you guys, but this blew my mind. The diesel pullers run a low compression engine.. Engine compression heats the air hot enough to ignite the injected diesel fuel. With the lower compression, diesel fuel has trouble igniting in the cylinder. This is why you see many of the diesel puller engine start with LOTS of ether assist. To build heat in the cylinder the puller will very slowly advance the throttle to speed the engine. If he pushes the throttle too quickly the additional fuel will cool the cylinder enough that the engine will die. As he advances the throttle he will load the engine by slipping the clutch. As the engine takes more load, the turbo, or turbos will start to build manifold pressure. As the manifold pressure increases the cylinder pressure rises allowing more fuel to burn. The more fuel that burns, the faster the turbo spins, the faster the turbo spins the more fuel. (you get the picture) As HP and RPM build the engine will finally be making maximum horsepower and the clutch can be released. And the pull is ON.. P.S. The low compression is so the turbo can pack more air into the cylinder without blowing a head gasket or worse. How amazing is that, it's squirting in so much fuel that it can put out the fire.
https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/lighting/cosmetic-lamps Having trouble making sense of the virm in regards to led spot lights and light bars. I'd like to put a light bar on the front of my roof tent, but it looks like I can't switch it from high beam? The table also doesn't let you mount a lightbar facing forward, going by the table. Am I reading it wrong?
If you just wanted to run the trike for now, I wouldn't be worried about the 02 sensors. I had a 92 UZZ30 and unplugged the 02 sensors and afm when trying to narrow down an issue. It ran mildly more rich but still ran great.
What would cause the damage to the bores?
It certainly does.
Can you fit this in the space you have? https://www.trademe.co.nz/motors/motorbikes/parts-for-sale/electrics/listing-2157455276.htm?rsqid=328059dc3efa49608edcfce1d4023725-004
No, there are many downsides. Lifepo4 is the business for automotive use.
Tried swapping brake pads between sides?
You're a maddog
Will you fucking potatoes just like Johnny's post instead of spamming the dick out of this bitch.- 895 replies
Gooch Gauntlet -
@JasonK @Cazza @Duddley
