Everything posted by kyteler
- 94 replies
- eunos
- eunos roadster
- (and 6 more)
You and your assistants to your efforts do good work. Keep it up.
Swaps for a shitty D21 VG30 5spd double cab beater?
Oh man. Jealous.
1988 Toyota 2WD Hilux front brake upgrade options
kyteler replied to johnny.race's topic in Tech Talk
Not all of them. The povo ones are 15 but the ones that he wants the brakes from are 16. That said, it comes down to barrel design. Some may work but not many, I'd have thought. -
Bronze’s 1963 Ford Galaxie Hardtop
kyteler replied to The Bronze's topic in Projects and Build Ups
Daaaaaamn. Long time coming. Grats! -
If the rear quarters have had the arch cut (which they probably should have to be able to properly fit a widebody) then as I understand it, that needs cert.
Put a rota in it? Awwwgoooo-on It'd be great. Don't let the Roadpacer steal the limelight. Falcon 20B-Pac
Is your rack on the piss? Looks uneven. Just the photo perhaps?
Cromwell Classic Car & Hot Rod Festival 16th Jan 2021
kyteler replied to Toddy415's topic in South Island Region
I have another booking that I must attend so I won't be able to make it. -
Stickers making cameos in Garage 4AGE vids. I've made it.
Chasing 2HP Roadster life.
On the plus side, they're not in my shed.
NPD 100Plus is one of the highest octane, road legal petrol products to be offered in the South Island from an established fuel retail network. NPD 100Plus is designed to deliver clean-burning power and efficiency and can improve throttle response from your engine. * NPD 100Plus is a specially formulated unleaded petrol with no ethanol content.
I guess it would probably pay to ensure you put some or run it on 100 or 98 when you get it back in use post paint sorting.
A combination of idle speed adjust and timing advance may be your friend.
Just stumbled across a post that said the auto ECUs run more conservative timing. Can you adjust the dizzy or Cas at all for a quick check or is it all ECU controlled on the 1GGZE?
Quick Googs seems to indicate that it's fairly common to just run the AT ECU but the tune or compensation will definitely be different. I've experienced the same problem with the R30 when I converted it. Luckily I had a swag of ECUs and one of them rang it good as gold, your Crown is probably a bit newer and fancier than the 30 but likely still suffers the same problem. I would guess that the tune is expecting the decel to take a lot longer due to the fluid in the torque converter but when it's just a flywheel it will dip far faster. That's just speculation on my part though. Even if you can't find a manual ECU, if you can get another auto ECU it would help troubleshoot?
Does it have a part number? Might be worth a Google to see whether it's designated as such through the catalogue.
I'm not sure when they started splitting them off but there are definitely differences and different ECUs between manual and auto to handle the change/tune. Like you say though, finding one may be impossible. Link or Haltech maybe?
Did you get a manual ECU?
Depends on the quality and complexity of the mould and the part.
Not something Palmside sells? Or some other Brit Escort specialist site?
It's not simply M13 is it? Because the British are fuck wits. I imagine you'll be able to get the nuts from an escort specialist but I would ponder whether you could die it down to M12 at a similar pitch.
- 94 replies
- 9
- eunos
- eunos roadster
- (and 6 more)
