Everything posted by Otodat
Turns out I only have 3 photos of this on my phone and this is from 2015, but anyway this is my 87 Nissan president Have done a few bits and pieces on it in the time I've had it, and generally it's been pretty unreliable, the latest problem it's got is running issues so a haltech 550 and wiring kit has turned up for it now. Fun fact- I don't know what I'm doing. Next step I guess is to gather some electrical bits like plugs idle control valve and some sensors of some sort. Going to try and follow to a degree what skid factory did on YouTube, looks easy on the internet, what could possibly go wrong?
- 13 replies
- 23
Good read thanks!
piazzanoob's 1964 ford Galaxie 500 seeedaan
Otodat replied to piazzanoob's topic in Project Discussion
Looks good! -
VK304's 1988 Nissan Vanette w/ added SR20DET
Otodat replied to Willdat?'s topic in Project Discussion
That's a fair bit of twist! Did the diff pop? Was watching with sound off -
Nice collection!
Well done on getting this going so quickly, can't imagine how nuts it is with that engine! -
Looks slick, well done!
That a12 block would explain the gutlessness on the hills you talked about, shame it’s not a15 -
Oh man, cool project. Will be watching with interest. -
Looks to be shaping up well, great job keep at it!
Beautiful car, looks so good.
Reg on hold
Haha yeah, nah, looked at it some more and it must be at a very old repair, looks as if the rear quarter has been replaced ( it’s black on the inside and the other side is white). Sure I could chuck a weld on there and it will be painted with the rest of the underside but this car is will likely need a cert for engine swap so I guess to reframe the question- if this was done the correct way what is involved repair wise and paperwork wise?
Was working under the Datsun today and spied this it’s on the chassis rail forward of the rear spring hanger. Anyone got any advice on what to do here?
Could that short driveshaft be off 510. Was looking on 1200.com and 510 is 1082mm u joint to u joint with h165 flange pattern but different spigot size. http://datsun1200.com/modules/mediawiki/index.php?title=Propeller_Shaft_Swaps
Option 4 seems like the easiest/cheapest way to go. Could you maybe put efi or throttle body injection on to save room, a lot of fafing about though. Or another option could be a right angle from the manifold to the front or back and put a su carb on? Anyways, keep at it, like where you’re headed with this.
Sounds normal Datsun spec then, never seen one in nz before, quite cool.
Hold up, is that an early 200sx you’re pulling that motor and box out of?
Welder review- for anyone interested. Ended up getting a weldtech 4015mp from an outfit in Christchurch and it turned up three days later. Had been meaning to get a 15A plug sorted out but new toy, so couldn’t wait. This is a multi process machine that does stick welder, plasma cutter and tig. Big part of getting this is the days of chucking the old young model b (pictured below) in the back of the wagon when I needed to weld something out of the workshop are fading. This thing is so light in comparison, and having a plasma cutter has been on my wish list for some years. First job was cutting out some new tilt linkages for the hedgecutter out of 10mm plate. It seemed to be approaching the limit of its capabilities as a plasma. It might be something to do with the way I’m using it (ie operator error) but I found it impossible to keep a straight cut. In the end I cut the shape slightly wider and ground the cut after to tidy it up. Was fairly slow cutting but this thing has a neat function where you can start it by depressing the trigger once and it will stay on until you lift the hand piece. After this I tried it on some 6mm plate and it cut through like butter, clean and fast. It works good enough for what I want to do, hopefully get better with practice. Next I tried out the welding function on some 10mm off cuts. Oh man, so freaking awesome, so smooth and heaps of grunt. Unfortunately at this point the 70 year old electrics in the workshop decided maybe to much grunt and the lights went out, which revealed around six power outlets in the shed were powered by a short extension cord near the toilet with going out one outlet then in another. so that’s all good, needed to get an electrician anyways. A week later some cracks started to appear on the head of the hedgecutter so threw the welder in the wagon the next morning. I was a bit dubious about hooking off the power from the farmers shed, running out a long extension lead and welding some fairly thick steel. I set the welder on 95 amps with some 3.2 rods and went at it. Job done-no problems. Pretty stoked, yeah it’s not weld porn but the thing stopped falling in half at least. In conclusion- this thing is pretty sweet. As a welder it’s probably the best one I’ve used. As a plasma it does what is says, but 10mm is definitely its upper limit. I’ve never done any tig welding before, for me it would have been absolutely ideal if it could be used as a mig. I asked the supplier before I got it if a spool gun type setup could be used on it, which would be adequate for my use, but they said it couldn’t be done. Bit of a shame. I may give the tig part a try one day when I have time just to satisfy my curiosity. At this stage would recommend to anyone looking for this type of machine. Hopefully it stands the test of time.
Possibly it would have a two stage relay for the fuel pump?
Yeah I could easily enough get a 15A plug put in the shed and a converter for when it’s out of the shed if need be.
Oh that sucks, other welder is out of aus, probably be a hassle gst etc i guess. Although same weldtech machine is in Christchurch for a little extra https://www.trademe.co.nz/business-farming-industry/industrial/manufacturing-metalwork/welders/auction-2238238817.htm
Looking at getting a new welder so dragging this back up. I need a portable stick welder for repairs but would like to have a plasma cutter set up in the workshop at other times. Needs to be able to cut and weld up to 10mm steel. These two on tm look like they would do the job. https://www.trademe.co.nz/business-farming-industry/industrial/manufacturing-metalwork/welders/auction-2237324533.htm https://www.trademe.co.nz/business-farming-industry/industrial/manufacturing-metalwork/welders/auction-2237872314.htm Will need this to run off normal house socket. When cutting/welding 10mm would it go for a decent amount of time without cutting out or am I asking too much? Keen to hear from anyone that has experience with them. Or alternatively I have 3 phase in the shed. Would it be better to get a decent plasma and a cheap portable welder?
Sweet vans, what’s the setup with that silver one?
Yeah the 55 is the id of the frame
