deankdx
deankdx last won the day on January 19 2022
deankdx had the most liked content!
    Outside NZ
2,244 profile views
deankdx's Achievements
Post Fiend
Post Fiend (4/5)
2.6k
  1. space to the shock tower is restrictive, use the EFI bananas and mount carbs above the rocker cover in place of the plenum?(might not fit under the bonnet and hot side intake not ideal.
  2. at least single rails have a different shifter location (from 6cyl cortina which is closer to the bell housing by 100mm i'd guess) no overdrive though. shifter housing is usually sloppy like a stick in a bowl of mud. but when re bushed are very decent shifting.
  3. I can't remember if you've mentioned it or not, but the Iron head on the XC has a different intake to the alloy, has a water outlet under number 2 intake port. I bolted an alloy head on an iron head once, I was told it wouldn't work (it did, but the locating dowels needed to be be binned ..none in the block on XC) I didn't use this engine for long, but it was a good combo of pre pollution cam, probably higher compression with the mix n match.. but smoked and burned oil.. was one of the most powerful stock crossflows i ever had though.
  4. T5s will put the gear stick a long way back depending what gearbox you end up using. (i should have used one when i did a 1UZ into falcon due to all the tailshaft/speedo etc would have just worked probably, but chose the W55 due to it being better ... probably.. if i had my time over i'd choose the T5 due to less custom stuff. ) based on your bellhousing though, then the input shaft will be something to consider, and the commodore V6 T5 does have a very long input shaft, (so does the ford V8 one from the E series falcon) There is a different shifter housing that fits the ford T5, not sure about the holden V6 one, but i assume so? from the USA spec Chev S10? (not cheap anymore due to age/scarcity..shipping etc) The W55 W56 W57 W58 have different stick positions, with the 58 being mounted further rear in most cases, i had the W55 in my falcon because it was available and cheap at the time.. gear shift feels lovely compared to agricultural T5 (overdrives vary slightly between them, not much though) see input shaft length mentioned on T5s, that looks like it might need a commodore V6 T5 for eg.
  5. deankdx
    diesel spam
    I was interested after seeing Top Gear USA decades ago probably do "project sipster" https://motoiq.com/project-sipster-part-7-sipster-indeed/ the goal was 7 seconds 0-60mph, 70mpg fuel economy for under $7000, and they did that but the fuel economy was over 80mpg (3 Litres per 100km ish from memory) I never looked into it further, was cheaper just to buy a car with that engine if wanted (I'm in Australia, and the gearbox conversions were in USA) there are kits to bolt them to various gearboxes, I considered one using a hilux 5 speed (W58 or similar) but Robot Cantina has an early VW diesel bolted up to a T5 (kit available) in a Chev S10 pick up in USA (current project, will be turbo'd supercharged etc later)
  6. I have ADHD also, which is why i understand the risks of "ooh look a squirrel" (side project etc)
  7. I noticed your poll doesn't include fixing the engine while still planning to set up a conversion with something else down the track. sounds like you enjoy driving it, so I'd be reluctant to pull it off the road for too long if possible.
  8. 5 cyl , make some decent doorts from the exhaust might be still wide and heavy, but have the VW gearbox already fitted.
  9. just came across this fun project i did a few years back.. (replica ish of what i made as a teenager) the Vbrake adaption was due to not getting the bike with any brakes, so cut them off the cheap donor bike lots of bodges on this one, I think starting with one of those 20" mountain bike frames would be the go (back wheel/derailleur /chainwheel etc would fit for starters) wheelie at walking pace is the result.. (this bike ended up scrapped due to a mate left it in the rain too long)
  10. yeah i can't remember, you'll see it if you watch the series. i don't see/remember how they are going to be able to weld those pipes to it? (cutting open and welding from the inside?) the whole manifold could be 3D printed with a saving in weld time alone surely. i think they may be setting up to sell conversion parts, so this may be a way to sell them in kit form (weld them yourself and save $2000 in labour?) the intake was very complex, i can't remember without watching it again but you'd probably see some interesting ideas of how they went about it.
  11. that might be old content also, because they didn't post for nearly 12 months. I commented with a suggestion they look into metal 3D print or that bracket they had CNC machined, as your success looks like that may be better and cheaper as in a better metal even. i stopped short of suggesting they check this thread out for the latest use of technology on a budget..
  12. that rust in the plenum, before you drill out 100s of spot welds. just check from under side if they are accessible (from under the dash) you may need to turn the car on it's side/upside down, or weld upside down (liquid metal falls in your elbow vein if not wearing leather sleeves) I've seen it done twice now welded from this side when the majority is solid. (have also seen just a section of the plenum cut out rather than the whole thing) just thought i'd mention it as an option before you get into it.
  13. I've read the AU falcon live axle is wide enough to clear the springs (make new spring perches to suit) it's still a narrower diff you you get the benefit of being able to use a deep dish wheel on the back if that doesn't bother you. (many ratios available for this diff in factory form from about 3.08, 3.27, 3.45 but you could get many more ratios if needed. CRS used to make a falcon front brake conversion (falcon discs, kingswood calipers) but not sure if they still do (Australia) and Hoppers stoppers may do something since? (Melbourne Australia )
  14. heaps of information on https://fordtransit.org/forum/ from memory the diff ratio is 5.6:1
  15. that's a fuel cut solenoid, stops run on when ignition is turned off. I saw this photo many years ago, i think it was mentioned it was 3 manifolds cut up and bolted on separately
