Pediigru
New Members-
Content Count
15 -
PEDIIGRUS 83 NISSAN SKYLINE COUPE (KHR30)
Pediigru replied to Pediigru's topic in Project Discussion
It was Andrews before it was Wilson's but yep. It's coming along. -
Pediigru replied to Pediigru's topic in Projects and Build Ups
So now that I have the engine and transmission out, I can start cleaning and degreasing everything in preparation to clean up the engine bay and engine itself. I've got to get the strut tower rust in the engine bay fixed up so I've been focusing more on getting the engine and trans cleaned up and what I'm going to have to replace in it. The trans itself cleaned up pretty well. I'm not sure if I should paint it or not yet. I want to ditch the blue and go black or dark grey instead. And either paint the gearbox black or dark grey to match. Otherwise I could probably just clean up the trans -
Yep LHS is through the firewall side but not the wheel arch side and the RHS has cracked on the engine bay side. The firewall looks good so its just the strut towers. -
So thanks to the long weekend, I had some time to finally pull the engine out. I started by dropping the driveshaft, exhaust and then the gearbox as I didn't have much room to go back once I had the engine lifted up. Ended up having to drop the front of the car down to get the engine over the front radiator support but i got it out in the end. There wasn't much left connected to the engine by the time I dropped the gearbox and power steering as I'd already removed the manifolds. Believe it or not, This is the first time I've pulled an engine out of a car. I've done manifolds and gearboxes -
Definitely. The ends of the wing will need a little love and repair but I'm planning to put it back on afterwards. I also have some R31 endcaps that look the part and fit pretty well so they'll go on as well after I've painted everything. When I pulled of the intake piping, I found pieces of metal wiring all through the turbo and intake, then on the pressurized side before the intercooler i found this jammed in the side. I have no idea how or when this got in there but it must have been before i got the car. Explains why it would boost at around 4500 though I'm surprised it boosted at -
So here we are today. I've pulled mostly everything off the engine. I have the exhaust out and driveshaft out. And I'm planning to remove the gearbox today or tomorrow and then last the engine. I'll repaint the whole bay whilst i have everything out and just give the whole thing a general tidy up. The intercooler piping was horrible and I'm going to be putting in a new front mount intercooler and radiator and tossing up the idea of putting an oil cooler in as well whilst everything is apart. Unfortunately I still don't have access to a garage so keeping track of everything is a bit of a m -
So throughout owning this car, I've been trying heaps of little things to get it running better on the engine side of things. I've replaced the sparkplugs, coil, distributor, ECU, rewired a bunch of the loom and although i got it running and boosting, it just felt.. off.. I was blowing oil out the back of the valve cover due no a dodgy gasket as well which wasn't helping my cause. Cold starts are rough. It will idle like shit and then suddenly come to life. So I decided fuck it and started to take the entire engine out. I checked the valves and timing to make sure nothing was wrong ther -
So this is how she's been sitting for awhile. I lost motivation to work on the R30 over winter and didn't get much done. I got a set of KYB shocks for the back but they're a laughing stock over the Monroes it had in it, So i just gave the Monroes some good old one way Makita treatments until I order the new TSD shocks. I already have the whole front end conversion waiting to be put in when I take the engine out. She was drivable but barely so it was mainly for just rolling it around the driveway. As you can see, I've had to sand down a lot of areas and bog in a few dents. to get everythin -
Well now the interior doesn't look so bad it really shows how bad the exterior looks. There's a few holes and dents here and there but i don't have time currently to panel the entire thing so it'll just be fix what i can for now and come back to the rest later. Pulled off the front panels and boot, removed the Adthree wing that was on it. That 3m sticky tape works good for keeping stuff on alright. Boot starting to get sanded down and filling in the dents and popping out the ones I can. I'm doing to ditch the SKYLINE rear badge as this one is pretty toast, I may see if i can fix it up la -
So we decided to tackle some of the interior pieces whilst we had everything out and apart. Even though I'm going to have to put it in and take it out again later it was wort hit for the pics alone. This was before we found the paintbrush under the carpet and when we were still taking everything out and apart. Thankfully no rust on the inside anywhere that we could find. The carpet and interior wasn't in terrible condition, The front dash is going to have to be pule out and repainted as it must be a replacement. Someone had cut a plate for gauges which was horrible and I have plans to rep -
I'm going to post a few of these older updates just to get the ball rolling. My partner and I started stripping down the panels to see what was hiding underneath all the interior, bumpers and panels. I was actually surprised to see that under the front panels wasn't too bad. Someone has clearly been in here before me though. The sills and doors seem okay surprisingly but there is a few patches that will have to be sanded down and repainted and resealed. The entire floor inside the car has been painted black probably with rust kill with a paintbrush. They left the paintbrush in the -
Discussion: https://oldschool.co.nz/index.php?/topic/77978-pediigrus-83-nissan-skyline-coupe-khr30/ Hey all, I'm pretty new around here but I've been in the old skyline scene for awhile. Most people know me for my 1986 Nissan Skyline Passage GT but I have a small habit for collecting hardtops cars as well. Earlier in the year I finally managed to pick up a KHR30 L20ET Coupe which has GT-ES Badges but I believe is actually a GT-EX. As you can see it's had a bit of a hard life so far. Overall it's in average condition. The interior when i got it was half put in with the roof lin
Project: Discuss. Have I really taken on more than I can chew with this damned rust bucket?
