NickJ
Everything posted by NickJ
  1. They're dishing out home d to their customers now?
  2. Had a generally good run out of the Niva recently, not that it really does much work, spends most of its life in the shed and then gets rolled out for weekends away. Went for a drive down south Canterbury way and found another Niva hiding away in daily use. Also had a look around a few of the high country valleys over winter: After this trip on rough river stones the steering idler once again slogged out, upon measure up I found the shaft is slightly undersize, that explains years of rapidly wearing out bushes! A quick call to a supplier and I had some nylatron through the lathe with much less clearance. And of course something big had to happen, on checking the car over before a trip I found a missing washer and screw in the intake, the screw was caught in the carb throat, the washer no where to be seen..... After trying the obvious, I made the call to strip the head in expectation of a gouged bore, but no, nothing seen but a few divots in the head and piston, it appears the washer made it to freedom via a brief beating in #4, once again, the gods seem to smile on me! Moving forward the Niva will keep hanging out in the shed with occasional weekends out, but come christmas improvements will slow...... This weekend I picked up part A of my legit black plated new project (cheers Greg!) while a few OS'ers know about my excitement, i'll wait till I pick it up to start the build thread, for now here's a teaser: And for those that don't identify as a drivetrain Barry....
  3. This is the constant pain with the Niva, I can get it pretty close by feel setting the brakes on stands at home, then heavy braking on a quiet road to be sure, often one side just needs a tad more to get it right and the wof guys seem to understand. It does suck though and is my main motivation to set up rear discs!
  4. Whats the go with spraying over rattle can, does it need to be stripped back or no worries?
  5. Thats cool, I was wondering what function a reactive metal had as an implant, very nice
  6. One of the top beer drinking locations in the country that ridgeline! Yarning with my brother (heli pilot) he mentioned underslung loads need consent from all the landowners flown over, (technically that includes roads) Shortest run possible, and make sure the loads are all as close to max as possible, no point leaving load capacity spare! They'd send out the ground crew to organise each load, chopper just pops in when its ready to run and game on. He mentioned a number of guys up your way with machines capable of helping out, shouldn't be too hard to get one to swing by on the way home!
  7. Guess I better quantify... I had issues with wilwood gear that came from insufficient tolerance and lack of suitable dust seals, this lead to uneven wear and seizing of pistons. This issue was made worse by soft Al castings that seemed to rely on the anodising to provide a wear surface, the moment that thin layer wore through, it was game over. We switched to a higher spec brand and all the issues were gone, however the environment the components were in was a little more demanding than a road car. I'll also add the importer we dealt with was a GC and worked with us to find the issues, really I guess we were using kit that wasn't suitable for the application, but the marketing hype was such that I was left to chase a bad lead for too long that it soured my opinion.
  8. cheap junk the stuff i've had to work with
  9. Well Karl has first dibs, but i'm happy to barter for datsun bits
  10. I have a pair of those guard mirrors......
  11. Going off 140mm of cut edge, then wirecut would be somewhere between $100-150 for just the serrations, would make a perfect part too
  12. How long is the toothed section? that will give a good idea as to edm cost
  13. Got some momentum going on getting this thing running, well done dude!
  14. Problem with making that is the teeth, would need to grind a tool specifically, or if you're moneybags would be a simple wirecut job.... Very simple part to draw up, the tooth detail is a bit light but could fudge it easy enough.
  15. I have a set of these, freight might kill but when ordered with other junk more than suitable. https://ladapower.com/catalog/tools/lada-coil-springs-remover-type-3-detail
  16. As I understood the sensor went on the bottom hose for fan switching, or is that just another way?
  17. I stumbled out of Alex's shed in the soft light of a golden bay dawn to have my morning piss when I saw that beast for the first time, as first impressions are everything, mine were along the lines of god that car is filth, how did Nissan get from Hakosuka to here? I wish you all the best for your future smoking holiday reds at the kennel club while placing $5 bets on your brother's mate's husband's greyhound
  18. By far my longest running project, built this benchtop power supply while at high school 20 years ago with the intention of installing volt and amp meters, but never really followed through, i've just been setting up a multimeter, with increased use recently I threw down $2.68 on Ali... Now the case is brutally oversize but modern, perfect!
  19. How does the efi twin cam pick up engine speed? where is the sensor(s) located?
  20. Awesome find, what is the story behind her, looks like someone has shown reasonable care up to now?
  21. Take the instrument cluster out and post separately?
  22. Which RT are you? My Niva is often stacked with toys when we're out and about
  23. Not Russian, but a large American van/camper, belonged to my grandfather in the 60/70s and my father found it in a shed in the far north, is now in his shed awaiting restoration, i'm that keen to see it run again i'm near organising the panel work behind his back, count yourself lucky Cook strait is so well placed! If you need yarns for the pick up mission Greg, get in touch!
  24. Was having a beer at last weekend's meet when I finally put it together which Greg you were fixing this up for (makes sense really) When he drives up to grab it I should either jump in for the ride or drop off the speeduino gizmos for delivery Also, your prices are very competitive, how do we book?
  25. Just select the resin on what you're doin (generally you'll have to post cure above the expected service temp) but resins do exist that can handle much higher temps. If you want to give prepreg a go, the silicon may be too soft, don't want to say it won't work, but chances are once the vacuum is on it will distort, dunno how much of an issue this will be? Also try printing the insides of the manifold and wrap the carbon around the outside, laying up prepreg on internal surfaces + vacuum is a pig.
