chris r
Everything posted by chris r
Keep charger and put a massive turbo on it. Best of both worlds. Water meth injection to keep it cool
I believe as a expat you can bring a personal vehicle back with you. Can't exactly remember the regs with the vehicle standards
Wow that's awesome. Keen to see more progress
I love how all lots of the broken stuff has broken exactly the same as my old 70 c10
Another +1 for checking/cleaning wheel seen sensors. Also check tire sizes/see if one is way more worn than the rest
I have always wondered about the blowers and how good they are. The storage boxes have nothing on the dealt dry boxes
Phone is being a dick my big rattle gun is a writer 18dshl and the smaller older one is a writer 18dl
/you are more than welcome to have a look/test my ones if you want
I have got two Hitachi guns. Both half inch. I highly rate them both. The smaller one is good for the majority of stuff (used to be auto sparky) and it's nice and light. The big unit is a bit on the heavy side but I have rattled quite a few crank pulleys off no sweat with it. I'll find part numbers when I get home
Auckland Monthly Meet - Wednesday 20th July 2016
chris r replied to Threeonthetree's topic in Upper North Island Region
It's not broken from doing borgies -
Sounds like a shitty earth. Double check / clean them all and go from there
Willdat's this wasn't supposed to be a project Honda Beagle
chris r replied to Willdat?'s topic in Other Projects
I have left power steering pump in but it does scratch the bay/can be a pain with dohc motors -
Leave the accord pump connected to the hoses then you don't need to get it regassed -
If the specs match up I'd say replace it. Its not like it cost you much or you can break it more than it already is
Nice. It is quite fun "testing" them in gravel/mud
It still works fine. Nothing electronic making it 4wd. The clutch in the diff only gets activated (disengages to make it 2wd) when you do a abs stop
Most honda abs/alb systems the accumulator/pump/seals fuck out. Noise could be the pump trying to build pressure? I ripped my system out. Need new master cylinder and all front brake hardliners/prop valve
I can do you some prices on new ones. That's a lot to digging!
So keen to see/hear this motor go
4.1 is a good effort. New daily did 5.2 average according to dash readout. Will do a service and see if it changes then I'll look into driving styles
Trying to put up a photo of the diffs the longer one is out of a alb car and the smaller is not. The snout has the clutch in it
It has the lever on the gearbox with both systems. It's a 10mm bolt by the speedo cable. Try put it in 2wd with that and see if it helps
I'm not a shuttle foamer... Honest
Non alb shuttles/beagles have a viscous coupler on the drives haft. The alb ones just have a clutch in the diff. The diff have a longer snout on them, They called it intrac before the beagles. It might even have a viscous Lsd in the back. I'll send you the manuals I have on it when to get home
