Everything posted by AllTorque
We fit genuine Toyota pumps all the time with no issues.
With the power of positive thinking.
FWIW Toyota trans service is drain and refill. No pan off or filter replacement.
The drain has a plastic tube inside it. You can remove it with a Allen key and drain some more. The top of this tube is the correct level with the trans in park and engine idling and the atf at 45 degrees C. We just put in the same amount that came out. Make sure you use the correct Toyota fluid. Should be WS, but the fill bung will confirm.
I have used them. You need to make sure the tyre is super clean with no silicone or tyre shine on there. You will need to re-do it often to keep it looking good.
Take them in to CDL’s work and they will tell you everything you need to know. They probably have some NOS pistons tucked up on the top shelf of the smoko room.
Oh, that makes sense. I was trying to figure out how it would spark without the earth.
You would want to remove the master cylinder and calipers.
Seedy Al's Chop Shop - The life and times of all my Crap
AllTorque replied to Seedy Al's topic in Other Projects
Shit that’s rad. Cheap too. -
Is the engine getting up to temp?
AllTorque replied to KKtrips's topic in Lower North Island Region
Help purchased a 50cc scooter only to find out its de-reg
AllTorque replied to weetbixkid's topic in Tech Talk
Word on the street is her a MR2B form from VTNZ, fill it out correctly, and ride off into the sunset. -
Yes
There is another form they should have given you identifying the areas to be repaired. It has generic car structure pictures that the wof guy should highlight problem areas. Anyone can do rust repairs, but the wof guy will be covering his butt, because he can’t see under the new paint. Ask him if you can take pics of the new metal before you paint it or take the car to him before paint.
If it’s not new it should be ok I guess. Maybe check the valve clearances
Is it supposed to be tapping like that?
Richy's 1991 Porsche 944 S2 - BEWARE OF SHARN.
AllTorque replied to Snoozin's topic in Other Projects
- 85 replies
- 6
- midlifecrisis
- notarealporsche
(and 2 more)
Tagged with:
- 85 replies
- 5
- midlifecrisis
- notarealporsche
(and 2 more)
Tagged with:
Rather -
Thanks Niki. Keep up the good work. I will be there to munch burger. -
What’s the plan? @Mourning Cupcake -
K-Trips 1982 Holden Commodore VH Discussion
AllTorque replied to KKtrips's topic in Project Discussion
What, no air guitar? -
I have to be in Palmy tomorrow soz -
How do the reflectors look? Put some relays in and some plus 50 bulbs. ...or Trans Am front.
