shrike
Everything posted by shrike
  1. Stock CA18DET rods should be pretty easy to get yeah? What are the specs of the forged rods for the 4G93T? I am guessing they are designed to work with forged pistons?
  2. https://www.speedhunters.com/2019/07/swapping-sixes-the-barra-powered-skyline-r32/
  3. Is this before or after its turbocharged for efficiency reasons?
  4. Good afterble consternoon, what do you mean I have no rear licence plate? Dam petrol thief junkies stealing my plate again
  5. I was going to say its time to find the Hybrid version for more compression and then realized the 4GR doesn't a hybrid version 5GR crank for less stroke? https://www.youngstarmotor.com/sale-42301339-steel-material-automobile-engine-crankshaft-for-toyota-5gr.html And some 5GR rods I am guessing to suit the lower stroke :p While I was having a look around, they are in development for the 2GR https://denstoj.com.au/products/2gr-toyota-engine-rocker-retainer-kit-by-denstoj?srsltid=AfmBOorA3rvKUNaD8zbd5PGwaiuHbx6VQzbMclxuEL08FcnIcIKc-o-J They already do an FA20/FB kit https://denstoj.com.au/products/fa20-fb-rocker-retainer-kit?srsltid=AfmBOoqp3gIOVdFmXS5jl8vM456uqwKgQtf4XRqkrwI0kNtDUUw1qWOz And one for the GR corolla/Yaris etc https://denstoj.com.au/products/g16e-gts-yaris-gr-rocker-retainer-kit-by-denstoj?pr_prod_strat=e5_desc&pr_rec_id=a7fc8dd21&pr_rec_pid=7004431941798&pr_ref_pid=7603717374118&pr_seq=uniform Even for the 4G63 :p Edit: Looking closer I don't think that kit solves the problem if the pin is falling out more googling required
  6. Prime opportunity to replace the downpipe and do a cat delete :p
  7. If you track something down in Victoria, I am happy to have stuff shipped to me and then shipped internationally if whoever you go through isn't keen etc just buy me a beer next time im in CHCH :p
  8. There is plenty of Subaru Brumbys over here in Oz, though shipping may be hard
  9. What version of subaru motor is it? Ive always thought a non turbo subaru motor with AVCS ie (EJ204D 140kw, EJ254 123kw but more torque) Or a later model FB25D 137kw (timing chain) or the Direct injection FA20D 153kw or FA24D 174kw along with the Subaru non turbo 6speed modified to run in reverse would be pretty sweet. I know a few of the above numbers can be improved on as well. Turbos are cool but harder to manage coolant temps, and you probably dont need the power in that light a shell
  10. So what your saying is you need to go on a holiday to italy to safe hand the heater back
  11. Ahh I thought they had completed it, bugger was hoping it would give a good blueprint Clearly you need to sort yours to 10k+ rpm and show them how its done haha
  12. Might be able to just replace the bearings?
  13. Clearly the answer is too mount the injectors spraying into the intake trumpets https://oldschool.co.nz/index.php?/topic/71963-inlet-trumpet-dyno-testing/page/10/
  14. All good no pressure, I'm currently in Frankston at the inlaws but I'm based out of Werribee
  15. @fuel how long you in Melbourne for and what part? Keen to grab a beer?
  16. Options for a hydraulic conversion?
  17. What boost did you end up running in the end?
  18. New shed skids
  19. Hopefully this isnt a suck eggs comment but get someone to video your first run (focusing on how it comes out off the line at the back) You want it to squat, 3 should be ok but see how it goes and dont be afraid to click it down to a 1 :p if your doing track/drift id start at a 7 and work my way from there Also im fizzing for everyone and im there in spirit
  20. So taking the daily down the strip or pushing the carina? I'm sure they'd let you push it down last run of the day I'm glad cars are held to a safer standard but I do miss the days it was possible to get a wof sticker posted
  21. That scratch is crying out for a sticker to go over it :p
  22. The Vinnyfab kit uses the NZEFI coils Vinnyfab kit They also sell just the loom/leads on there own Vinnyfab Loom/leads That's a bugger on the TM ones wanting pickup, oldschool freight?
  23. Ahh yes so SakeBomb is in USD so similar pricing to what I was trying to find more locally That TM link for buy now $77 might be useful if they are in spec as spares depends if you want to gamble tho At least the ones you have being in spec helps
