shrike Posted July 29, 2024 Posted July 29, 2024 3 hours ago, GARDRB said: The seller tells me that he's loaded a base map onto the ECU, I wouldn't be surprised if it's 4age based and he's set it up for my sensors. So it's not completely from scratch Setup for your injectors? Quote
GARDRB Posted July 29, 2024 Author Posted July 29, 2024 12 minutes ago, shrike said: Setup for your injectors? Probably not, we haven't even chosen injectors yet, I think we talked about using 4age ones, but we may look at using something modern Quote
Roman Posted July 29, 2024 Posted July 29, 2024 Be careful as some older injectors are low impedance and will blow up injector drivers 2 Quote
GARDRB Posted July 29, 2024 Author Posted July 29, 2024 3 hours ago, Roman said: Be careful as some older injectors are low impedance and will blow up injector drivers Yeah I’m aiming for some high impedance ones Quote
shrike Posted July 29, 2024 Posted July 29, 2024 1 hour ago, GARDRB said: Yeah I’m aiming for some high impedance ones Not sure if this helps or if you want to stick with Toyota injectors, they should all be high impedance, Toyota 2AZFE injectors are the newest style (12 hole) you can go for before they switch to extended pintles (think thats the term) 2AZFE pretty sure they are between 310-340cc from memory and were one of the largest factory sized toyota injector that was common (dont quote me) K24/20 injectors are 310cc but they are 6 hole 2000 year release design v 3RZFE are 300iish cc and similar design 2ARFE goes to the extended design and are 368cc 2008 year release design 2 Quote
Stu Posted July 30, 2024 Posted July 30, 2024 Ive used 4efte injectors in a heap of 4ages over the years and they seem to work pretty good and are plentiful/cheap. Ive probably got a couple of sets with plugs if you needed some. 2 Quote
GARDRB Posted July 30, 2024 Author Posted July 30, 2024 9 hours ago, Stu said: Ive used 4efte injectors in a heap of 4ages over the years and they seem to work pretty good and are plentiful/cheap. Ive probably got a couple of sets with plugs if you needed some. Are they high impedance? Quote
shrike Posted July 31, 2024 Posted July 31, 2024 8 hours ago, GARDRB said: Are they high impedance? They are 295cc from memory as well Quote
87creepin Posted July 31, 2024 Posted July 31, 2024 I’m sorry to spam this thread but I’m just here for the 4A chats. engines before it like the 2T/4K and after like 1NZ get me foaming too. Quote
