On 13/01/2024 at 17:14, mjrstar said:
Is there any chance that mx5 light motors would be the same?
Yes my thoughts too and they work fine but not the same mounts
  • Replies 68
Adrenaline r are good, I have a single 3.5" at the back on my car
When I was doing noise testing they were a muffler that actually worked, rotaries usually needed a couple of them though.
Yea i currently have a surge tank and pump occupying the other side haha so thats not an option, but ill get around to doing it properly soon
For exhaust, I removed a stainless adrenalin R off my RX4 as I couldn't stand the sound it made, horrible tinny and had a resonance at a certain RPM that just drilled into my head.
Not a fan.
I had a custom "Manawatu mufflers" mild steel boiler made to suit the space available, huge difference, really nice deep sound, slightly quieter, way happier.
Hope its not too bad but yea should be cool to see what its like, when it got real bad it sounded like 1 rotor was going and lots of backfiring and water pushing out of the radiator, did a compression test but nothing really stood out there, if its cracked there does that mean buy a new one or is there a way to save it?
My engine builder said
" Normally it's lack of coolant and I would replace ( if irons cracked). Not worth a dodgy repair taking everything out.
I'd be putting it down to corrosion, rusty coolant passages my guess "
Could be caused by a number of possibilities really, cracked housing, blown water seals, cracked plates.
they usually still comp test fine too.
Atleast you know it’ll be good after a rebuild
My irons were mint with no corrosion at all but the metal between the water jackets and the seals is pretty small. Apparently it’s pretty common for it to break.
