Dudley Posted December 19, 2023 Share Posted December 19, 2023 51 minutes ago, kp60nick said: I have an og trd fiberglass roof wing from jp that I've had a mould made. Could potentially get one made if you are interested? What sorta $$$ Quote Link to comment Share on other sites More sharing options...
DirtyThirty Posted December 19, 2023 Author Share Posted December 19, 2023 53 minutes ago, kp60nick said: I have an og trd fiberglass roof wing from jp that I've had a mould made. Could potentially get one made if you are interested? Could be keen depending in pricing next year? Just sorting ECU and wiring at the minute so a fair $$$ sunk. Quote Link to comment Share on other sites More sharing options...
kp60nick Posted December 21, 2023 Share Posted December 21, 2023 On 20/12/2023 at 12:17, Dudley said: What sorta $$$ On 20/12/2023 at 12:19, DirtyThirty said: Could be keen depending in pricing next year? Just sorting ECU and wiring at the minute so a fair $$$ sunk. Looking at $500 in glass or $800 in carbon fiber. still yet to pull one from the mould can start making them early next year. 1 Quote Link to comment Share on other sites More sharing options...
DirtyThirty Posted December 21, 2023 Author Share Posted December 21, 2023 3 hours ago, kp60nick said: Looking at $500 in glass or $800 in carbon fiber. still yet to pull one from the mould can start making them early next year. I'd probably be more inclined to go with a FG one Quote Link to comment Share on other sites More sharing options...
DirtyThirty Posted January 4 Author Share Posted January 4 Anyone have a comprehensive list of all the damn KP bumpers and mounting points? My bumper needs to be for a flat front BUT mounts to the frame. Others I have seen mount to the wall above the frame vertically. None of the current mounts I have will work unfortunately and I really need something to work. Quote Link to comment Share on other sites More sharing options...
Adoom Posted January 4 Share Posted January 4 Sounds like the same as mine? There is a lot of business going on in mine that is in the way, but hopefully you can see what is going on here. The bracket also supports the indicator. This is the right side mount. 1 Quote Link to comment Share on other sites More sharing options...
DirtyThirty Posted January 4 Author Share Posted January 4 1 hour ago, Adoom said: Sounds like the same as mine? There is a lot of business going on in mine that is in the way, but hopefully you can see what is going on here. The bracket also supports the indicator. This is the right side mount. So that's the mount and corresponding bumper I have. But not the one I need, my chassis is set up for the type that bolts to the frame from above rather than sideways. If that makes sense! Really appreciate the photos man! Helps rule it out Quote Link to comment Share on other sites More sharing options...
DirtyThirty Posted January 21 Author Share Posted January 21 Note: earlier and later KP Starlets have a different ignition switch. They're specific to if your barrel has a flat bottom or round. The earlier completely round barrel style ignition switch is too small in diameter to fit into a slant front (flat barrel) type ignition which has a 40mm diameter for the ignition switch. Quote Link to comment Share on other sites More sharing options...
DirtyThirty Posted March 31 Author Share Posted March 31 Anyone got a slant front glove box striker? Also any recommendations on someone to swap the diff mounts from my starlet diff to a T series? Also want to add a panhard bar mount while they're there Quote Link to comment Share on other sites More sharing options...
