Valve radio converted to guitar amp questions
ThePog
I got it into my stupid fucking head to build a guitar amp valve mini stack along the lines of this old tiny Marshal stack i once used which was awesome. It was a wee head with two channels and the first channel had been preamped into the second for mega valve gain.
Obviously I aint paying for no fucking Marshall so i figured a couple of valve radios might do it or maybe an alix kit.
If it is a radio does anyone have anything or know what would be best to look for? I am imagining that radios without transformers are probably a no go.
What you reckon?
I ah, have a set of photocopies of Marshall etc circuits (hand drawn - no less). May include marshall valve amp circuits. Want me to scan some up?
Shit, come to think of it, I prolly have some valve transformers and caps lying around in the junk bins.
One channel may have used an old TV knob, which went to 11
13 hours ago, smokin'joe said:
so you want a cheap valve amp ?? may know of a couple of Holdens and Jansens, and you should have asked a week ago, as currently in kaikoura !
Well kindof but I want it pretty small. I think the one I used was like this; https://www.kbbmusic.co.nz/marshall-dsl20h-dual-super-lead-20w-valve-amplifier-head-w-reverb-pedl-90012-2-btn-f-switch
But it was real oldschool, no effects and two seperate 20w channels, no light up power switches or anything. plus it was done in a cream fabric and had a couple of matching single 10" speaker cabinets. It was amazing.
Recreating that is the aim.
13 hours ago, Truenotch said:
Haha, I actually own an old valve radio and was planning to do this a long time ago.
Still pretty keen to do it one day, do you have a method in mind, or going to figure it out as you go?
Bludgeon my way through it without really knowing what the fuck i am doing I imagine.
The schematics could be worth it, there are valve amp kits on AliX that i could adapt maybe? Even router my own pcb's if i get excited.
Cool, have a go. I see this one has an LED under the tube, for extra heater glow? (LoL) https://www.aliexpress.com/item/1005005125142338.html
I don't see audio transformers in the kits I've glanced at, and I suspect a lot of the sound you liked is in the big valve power stage with the 300V to 8ohm iron output transformer, but,
have at!
Also, Public Service Announcement
High voltage dc power supplies for valve amps are notably dangerous. Use safe working practices like clear easy off switches, properly grounded chassis, isolation transformer and having someone in the workshop when fecking with the nasty bits.
have at!
Do you reckon those amps work without the valve even plugged in?
Wouldn't surprise me.
As you suspect/know i have no idea what to do irl. I suspect if i could look at schematics it would give me a better idea if its worth going down thd full diy track, which would probably be the most satisfying
Also; Safety notice received und understood....
4 minutes ago, h4nd said:
That is indeed charming looking, but is only the rectifier (not an amplifier)
What even is this
"The 6H2 rectifier tube belongs to the vacuum space charge movement mode. It moves in the crystal grain relative to the semiconductor current, and has a time lag effect on the front and back drops of the audio signal waveform. In addition, under the vacuum condition of the bile duct, the charge cannot have solid impurities Particle collision. The original ecological rectification is beneficial to audio transmission."
Quote
"Especially for small size, those who are interested can compare it by themselves to get pleasure."
:wub:
In the video which Hand posted, the narrator literally thanks Barry at Amp Maker around 16:55. :grin:
I imagine that any valve amp which has a 12VDC input instead of a big AC transformer must be using a step-up voltage converter to produce the high voltage which the valves require. This seems to be what my nixie and magic eye tube kits do. It goes without saying that big transformers are more hipster. 8)
My brother once had the valve radio from our bach house modified to take an auxiliary input. The idea was that you could play music from an iPod etc through the radio's amp instead of being limited to whatever stations the radio could still receive on AM. If that modification was done in such a way that a line-level signal was required, I guess you could still play a guitar through it by using something like an overdrive pedal to act as the guitar preamp? I could ask my brother where he had the modification done to the radio, but it was years ago - the Barry who did it might not be in business any more.
^yes, re power supply, but you still need to get from 600V at 0.1A down to 22V ac at 3A for the speaker, so prob still need the audio output transistor (unless you're rocking electrostatic speakers, but they're very rare).
^Volume control mod, yes, genius!
