MACKAZ
Holley carb talk.
What I would do is wire the secondaries shut, half a 600 should be about right. Make sure the power valve is OK and set the float levels. Years ago a mate had a nasty 265 Hemi with a 600 on it and a really big spring in the secondaries (basically never opened), Changed the spring for a lighter one, it didn't go any faster but drank a heap more fuel.
Share this post
Link to post
I've just thrown the kit in it, but God knows how but 2 of the base screws have vanished. WTAF?? Go hunting....
Share this post
Link to post
Regarding the transition, the "transfer slot" which supplies fuel mixture at part opening until the airflow through the venturis is sufficient to draw fuel through from the main circuit, these are metered off the idle screws. So if its lean just off idle, I'd fatten if the idle mixture screws a bit.
On the subject of the idle screws, if the are foil stickers on the metering blocks around the idle screws, then it's a "reverse" idle screw. Where it controls air to the idle circuit instead of fuel. (Some emissions bullshit) so winding it In makes it richer, and winding it out makes it leaner.  Often the foil is still visible, but the "reverse" part is no longer legible.
Share this post
Link to post
20 minutes ago, RUNAMUCK said:
Foil stickers
Hasn't got any of those. I found the instructions difficult to follow, appeared blurred, and had different options to what my carb has. I found it bloody confusing. Ended up finding clearer documentation through holley.com.
I'm curious to find out what it's been jetted for having #60 in it instead of its original #66.
Under usual circumstances I'd be grabbing another carb off Dad, but with him being retired the stream of parts has dried up....
Share this post
Link to post
I dont have anythin technical to add than has been already...
However my reason for wanting to post was purely to say thank fuck no dick has said to put an edlebrock on it, go way better and never need to tune it again!
Argh, i hate those cunts with a passion.
  • Haha 1
Share this post
Link to post
Ha!
I was totes going to suggest a 500cfm 4bbl carterBrock!
They're a spreadbore, so small primaries for tootle-ing around. And big holes for when you're doorting.
Plus they have a draft door on the secondaries. So even pegged wide open, the engine never gets more air than it can pull. Perfect for a small* engine like the O.P. has. (No over carburation issues)
Also plus, they cant leak because the bowl is sealed.
You really need to buy a tuning pack of jets and needles to set them up right Is all.  The 750 on dads 418 goes whizzer. When you open the secondaries at 50mph, the car tries to change lanes.
Share this post
Link to post
After rekit, a bit of fluffing around with float levels and dissy timing and it sat there idling by itself. I'll probably drop down 2 or 3 jet sizes as smells a little rich. And rev.... Oh my....
Share this post
Link to post
Ditto this, hate them with a passion. Must get around to swapping mine out.
Share this post
Link to post
3 hours ago, RUNAMUCK said:
How many cfm is it?
600. I am monitoring oil level. Have seen oil being "made" by overfuelling in truck engines
Share this post
Link to post
I actually meant @Thphantum's edelbrock. Lol
Share this post
Link to post
14 hours ago, RUNAMUCK said:
How many cfm is it?
I'm not sure. It's on a big block Oldsmobile rocket. All the yanks use them, I don't like them. Have played around with holleys a lot over the years and find them a lot more tuneable. I picked up a new 600vs with manually adjustable floats (old school)  when I was in the states last time. Just got to get off my ass and fit it.
Share this post
Link to post
35 minutes ago, RUNAMUCK said:
Really need a tuning kit to get them spot on.
I might strike up a tech sharn about this over ales and bbq'd meat at lake Waikerimoana
Share this post
Link to post
I was thinking more about scavenging your carterbrock. Lol. But I probably dont actually need it. I agree holleys are pretty simple
Share this post
Link to post
I wont be using it again after it comes off. I'll do some research and see what model it is next time i'm in that particular shed.
Share this post
Link to post
