MRWEST Posted August 19, 2020 Posted August 19, 2020 Damn man thats cool asf! Nice work. Suits those wheels and will be fun as with the Honda! Quote
dabuzz Posted August 19, 2020 Posted August 19, 2020 100% will not hate on a motor swap - if i owned it id have a 13b PP rotary in it before sunset. looks like a great car, your choice of motor will have it singing 1 Quote
Truenotch Posted August 19, 2020 Posted August 19, 2020 Nice work! Looks like the original engine was either a 2T or 2T-B pushrod engine. The 2TG was a twin cam. Either way, an F20C is definitely a good upgrade! Quote
Roman Posted August 20, 2020 Posted August 20, 2020 Just saw this thread, holy shit! hahaha. This is gonna be wild. love it. That diff setup with the camber is bloody cool. Quote
Matt G Posted August 20, 2020 Author Posted August 20, 2020 4 hours ago, Truenotch said: Nice work! Looks like the original engine was either a 2T or 2T-B pushrod engine. The 2TG was a twin cam. Either way, an F20C is definitely a good upgrade! Yes you're right, good engine from memory for what they were, way ahead of their time with the 5 speed. Quote
Roman Posted August 20, 2020 Posted August 20, 2020 Also I think you're the first person on OS who's baller enough for a PDM install. 1 Quote
Matt G Posted August 20, 2020 Author Posted August 20, 2020 1 hour ago, Roman said: Also I think you're the first person on OS who's baller enough for a PDM install. Being an electrician, I hate wires and love software. Also it fitted with the Haltech plug and play + dash, it all talks together. I hope... Want the analogue stuff like fuel level feeding into it, fuel gets low ill restrict it to only 9k RPM to get to the gaser quickly, see all makes sense and totally practical. 1 Quote
seb1009 Posted November 15, 2022 Posted November 15, 2022 On 19/08/2020 at 10:56, Matt G said: Custom EN26 drive shafts, light and should be more than adequate for peeling the tread. Ball Bearings fit in the end for the CV. Diff being assembled after painting with por-15. Ended up going with 1.25 negative camber and a fraction toe in on the rear. Adjustable so we can sort later with different blocks. Hey mate how much was this total build for parts cost and maybe the labour if you did the welding yourself don't worry just the cost for the rear differential and the rest of the goodies you put on it please and thanks One more what exactly is it out of out beside a hilux? Model and year, or diff code even. Or one similar that would still work. I understand I need to make a jig up to weld the mounting points on. Quote
