lush Posted April 25, 2020 Posted April 25, 2020 Looks nice! Digging the hubcaps and white walls Quote
TauRag Posted April 25, 2020 Author Posted April 25, 2020 Ha cheers rb drifter ! The hubs polish up real nice and the white walls will be getting a refurb for final effect. Quote
maxted Posted April 25, 2020 Posted April 25, 2020 Yeah I agree looks really good on hub caps and whitewalls, cool that its a ke20 2 door don't see many here in NZ. Quote
cletus Posted April 25, 2020 Posted April 25, 2020 looks cool! are you going to repaint the same colour, use same wheels and engine etc? Quote
2sik25 Posted April 25, 2020 Posted April 25, 2020 Very nice, i do like the 2 door ke20 very keen to see this come along 1 Quote
TauRag Posted May 11, 2020 Author Posted May 11, 2020 Yip will be painting in the same white , wheels engine etc. I actually really like it as is , just need to get the hidden cancer out of it and save her for at least my lifetime. 1 Quote
1vaknd Posted May 11, 2020 Posted May 11, 2020 the process you mentioned for deoxidine is correct except ive only ever used water not metho, the protective layer is minimal and wont hold up if the car is left outside overnight. if the deoxidine goes powdery you havent washed it off enough before drying. if the manel gets a rusty orange haze you havent dried it fast enough, you are after a rainbow haze over the bare steel best to strip, send to blasters. get it home. spend a whole day with a vacuum and an air gun. then deoxidine, then lay some quality etch yourself Quote
TauRag Posted May 11, 2020 Author Posted May 11, 2020 Hi 1vaknd. Thanks for the info. The blasting guys will be painting it in epoxy after blasting using Carboguard 504. https://altexcoatings.com/list-products.php?mid=12 So I need something that will keep the metal "clean" of rust while I work over the car until it is at the point that it can go to the blaster. They reckin that while blasting if there is any surface rust they can just "sweep" over it and it will be gone so heres to hoping. Quote
Dudley Posted May 11, 2020 Posted May 11, 2020 Wipe some epiphos on the bare steel. Seems to keep surface rust off quite well on bare metal cars while we work on them 1 Quote
AALAWS Posted May 12, 2020 Posted May 12, 2020 I stripped all the large flat panels, and a few other bits, with the 3m strip disks (great for chewing out bog) and then cleaned up the panels and wiped on some Keyphos - simple as. My first shell has been left like that for years with no issue - I've occasionally touched up the odd spot. I had the rest of the shell blasted by waikato sandblasting in Hamilton with ok results. 1 Quote
AALAWS Posted May 25, 2020 Posted May 25, 2020 I got my KEYPHOS from car colours on the north shore. Quote
TauRag Posted May 26, 2020 Author Posted May 26, 2020 6 hours ago, AALAWS said: I got my KEYPHOS from car colours on the north shore. Thanks AALAWS , I have sent them a email. Legend. Quote
TauRag Posted May 27, 2020 Author Posted May 27, 2020 Below is the reply I got from Car colours. Yes we stock Kephos, it is now known as Bonderite 253 also previously known as Paint Grip. My pricing is $49.29 incl for 1ltr or $181.92 for 4Ltr Freight is about $5. I can draft up an invoice if you want to go head Cheers They were really good to deal with and took my order over the phone.. recommend, would trade again. Quote
1vaknd Posted June 2, 2020 Posted June 2, 2020 car colours are actual legends, i deal with with them often Quote
