MARTS-PL310 Posted January 31, 2019 Posted January 31, 2019 (edited) 61 Datsun Bluebird PL310 De-Rustification Project. Build: https://oldschool.co.nz/index.php?/topic/60264-marts-pl310-61-datsun-bluebird-sedan/ A brief history of the Bluebird. It has a tortured past, mostly before I owned it. Yet it still runs but with a rather rusty floor and sills. Based on the evidence provided by the body damages, towing bills, and other repair bills that were obtained when my sister bought the car in Seattle, in late summer 1974, here is what I surmise happened along the way to present time. Early time period. Prior owners are suspect 60's era hippies that drove the car off road through the rain forest along the Washington state coast as evidenced by various underbody impacts against the floor braces and sills. You know, low speed dents from small stumps, rocks, etc. From the late 60’s to early 70’s? The car was T-boned on the right front door and fender as evidenced by new replacement panels and still damaged “A” pillar. 1973. Records supplied with the car showed a complete overhaul of the transmission due to popping out of high gear complaints. A worn 2- 3 shift fork and other items were to blame. Later that same year, the car was rolled onto its top and yet was still driven after rescue from the tow yard and only replacement of the windshield. 1974. My sister wanted a cheap car to get from Seattle to Los Angeles and bought the Bluebird in spite of its now beat up state and damage history. Before embarking on the trip to LA, I volunteered to help smooth over at least a dozen or more small dents with hammer, dolly and filler. I couldn’t do much for the roof then but it was not too bad overall. The front inner and lower fender structure and skin had already begun to make a significant rust hole that was then covered over with fiberglass. I also replaced a slipping clutch disk. Off she and Bluebird went to LA. 1975. I bought the Bluebird and drove it from LA to Seattle. No problems. 1975 to 1979. I used the Bluebird for mainly cross Washington state trips over the mountain passes. I bought a parts car, an ivory white 62 PL311, 60 hp model, from the wrecking yard to supply spares as even then it was getting difficult to source parts. Almost all of the spares car is long gone now. In early 1979, I drove the Bluebird to LA and back with no problems. Pic. Coast cliffside pullout photo on California Hwy 1 near Big Sur. 1979. 1979, summer. I bought a 71 Datsun 510 2-door replacement car. I kept the Bluebird as a second car. 1979 to 1985. Storage and neglect. I was working out of state for 18 months. The Bluebird began to deteriorate in outdoor storage and only rare driving. 1986. Took the Bluebird out of storage and began some work to “tune up” the roof. The previous repairs from 10 years ago had begun to blister and peel under the cover of a plastic weave tarp due to rain and sun. So I took the front and back glass out and cleaned the roof panel completely back to bare metal and worked it a lot smoother. At this time the rubber glass seals were ruined from rot and could not be reinstalled. This led to little movement of the car thereafter. 1987 to 2004. Bluebird is stored in my garage and only rare maintenance work is done to keep the brake slave cylinders from rusting solid. The fuel pump diaphragm goes bad and floods the engine crankcase with gasoline. Had to convert to a cheap electric pump to keep it moveable. The floor and sill rust progressed even when in dry storage. It is insidious rust that begins on the inside of the sills and under the vinyl floor covers. Above the floor the car has remained very rust free. Even in dry storage, rust does not stop in those places that became damp in the beginning from trapped moisture. More on that topic later! 2016 to 2017. Finally finished the redo of the roof and painted it with ivory white by having the spare and installed 62 PL311 car door jamb scanned. Going for the two tone look eventually. 2018 to 2019. Having removed the doors, interior, hood and trunk lids for the long delayed roof painting in 2017, the long hidden floor rust was now visible and really bad. The sills were also deemed so rust perforated and weakened that I would not consider removing the rotted floor until the sills are reproduced and welded in. And the remaining original left side fender was rotted out along with the bottom of the ‘A’ pillar. That all had to be fixed first and is now done but I could still use a right side ‘A’ pillar or else make it from scratch. Then the rear dog leg or ‘C’ pillar and adjacent side of rear seat floor rot out had to be made structurally sound so the new sill could be welded to solid metal. More all new metal fabrication fun. Anyway it goes on and on bit by bit. Maybe I can still salvage the top of the trans tunnel part of the floor but that’s about it, everything else related to the floor has to be cut out and tossed. No parts are available and all has to be fabricated from sheet stock. It is going to take a while. A few hours during the work week and same on the weekends are all that I can do. It may still be a few years before completion. One odd discovery. A previous owner had stuffed copious newspapers between the floor and underneath the vinyl floor covering. The barely legible dates read February 1967. Why would anyone do that on a then six year old car? I guess the newspapers made for a good sponge to hold water and keep the floor nice and moist to really speed up the rust process! Edited October 31, 2020 by MARTS-PL310 add historical photo 7 Quote
yoeddynz Posted February 2, 2019 Posted February 2, 2019 Wow. Its amazing that considering all the various damage to it in its early years it was kept on the road. I can't imagine that it was a particularly expensive car but obviously it had enough charm to get the love required. Cheers for taking the effort to write a thread here. Are there many of these left in the states? Any clubs? Quote
MARTS-PL310 Posted February 2, 2019 Author Posted February 2, 2019 6 hours ago, yoeddynz said: . Are there many of these left in the states? Any clubs? @yoeddynz. It is likely that there are no running examples of the 310 left in the U.S., including mine, at least while it is down for major rust repair. I've noticed numerous examples of the later model Bluebird 312 with the wider grill and larger taillights. Some 312s are preserved in very good condition. The 310s though are indeed very rare Datsuns. Only one has been witnessed in traffic in my entire life. It could have something to do with a significant axle weakness and low numbers of the 310 type (sedans and wagons) sold. I managed to break two axles in one year before upgrading to the stronger Bluebird 311 and 312 design. This necessitated swapping the entire rear drive assembly due to nearly all the part designs changing. Maybe only the wheels studs carried over? ; ) Nissan quickly engineered many of the rear drive assembly parts to be more robust, and to accommodate the 60 hp engine, including; axles, bearings, ring and pinion carrier, differential, axle housing, brake backing plates and drums. Yes, there are clubs with a few of the early 60's pickups, some later 312 Bluebirds, and all the other popular models that followed, but no members owning running Bluebird 310s that I know of. 5 Quote
MARTS-PL310 Posted February 2, 2019 Author Posted February 2, 2019 More Bluebird history. I love driving up into the mountains. Then, now and always. One of my favorite Bluebird mountain pass crossings back in June 1976, westbound on beautiful highway 20 through the Washington North Cascades. For the 48 hp Bluebird on the steeper grades, this was nearly always a maximum power event, pedal to the floor and changing down to second gear very early. 9 Quote
Teighballs Posted February 4, 2019 Posted February 4, 2019 What an amazing history! As said, thank you for taking the time to share! I have to say I got quite excited when I saw that 'cuda in the background of your second photo with the white billboard/white top! Cheers Quote
MARTS-PL310 Posted February 9, 2019 Author Posted February 9, 2019 What 40 plus years did to a tire on my 61 Datsun Bluebird! A slight bit of tread separation from the tire inner carcass and belts. Tossed it away of course. 3 Quote
MARTS-PL310 Posted February 9, 2019 Author Posted February 9, 2019 A historical engine comparison. The 61 Datsun Bluebird engine then, 1975, and now, 2019. The 48 HP engine back in 1975 The same engine bay 44 years later with the 60 HP engine in 2019. Same radiator, valve cover, distributor, battery hold down frame, etc. The 60 HP engine was salvaged from a wrecking yard PL311 Bluebird in 1976. Still missing the second fan blade! but does not affect cooling at all. Generator is from a 59 Chevy truck. 3 Quote
MARTS-PL310 Posted February 9, 2019 Author Posted February 9, 2019 More history. I could move this to the project build but I'm not building or changing anything. I'm content with leaving the instrument panel about the same as it was and is. It all works except the inop radio which was probably damaged by the maximal cruising revs and resonance from the engine. Some historical photos follow the current as is photo. The 61 Datsun Bluebird dashboard or instrument panel. How do you like those stainless steel rods supporting the steering wheel rim? Classic! But probably deadly in a crash. 1970's photos: Just another snowy day. Inspecting the Golden Gate bridge. This radio couldn't hack the vibes. It failed a couple of months after I replaced the previous failed unit. It's still installed only to fill the hole. 4 Quote
MARTS-PL310 Posted February 9, 2019 Author Posted February 9, 2019 And why am I in the house messing with old photos on Saturday morning and not outside or working on the Bluebird in the garage? Because the weather has taken a turn for the worse and it's just too darn cold. My poor 86 Chevy Caprice is outside. Brrr. 4 Quote
Adoom Posted February 10, 2019 Posted February 10, 2019 Wow! Slow down you maniac! You put the rest of us to shame. 1 Quote
yoeddynz Posted February 28, 2019 Posted February 28, 2019 Far out!!!! So much rot. Good on you! Is it in your own workshop where you're doing the work or at someone else's /some business? Youre certainly diving in at the deep end for someone new to mig welding. Cheers for the detailed updates. Quote
MARTS-PL310 Posted March 2, 2019 Author Posted March 2, 2019 @yoeddynz. Working the project at home in my off work time. My workshop is basically a home built wooden table, on wheels, containing an assortment of tools. Move the other car out, roll the table and welder out and have a go at it. MIG welding is fun, almost addictive, whereas forming flat bits of metal into original shapes is hard and is probably 95 percent of my labor time. Often the parts are made into rubbish and I start again. I feel like the welding action is my reward carrot for getting parts made well enough to look and fit good. Currently, I've about finished reconstructing the jack lift point structure that nests inside the outer sill panel. I'll try and post some more pics on the build tomorrow, time permitting. 4 Quote
bananahamuck Posted March 13, 2019 Posted March 13, 2019 Hello,, are you still in the northwest ? Have you heard of a Datsun show that was held in a town called Canby ( south of Portland) .. Well that show was ran out of fairgrounds by the powers that be ,, so it has been moved to a place just north of Salem called Powerland NW .. It's a huge place that normally hosts tractor/thresher shows... Anyways,,,, if you never been, there is usually over 200 Datsuns from many states and Canada.. Even if your car isn't done you should go to it,, it's a great way to charge your Datsun batteries.. A 2 day event,, Saturday ( there is camping on the grounds) , and ,, Sunday is usually a early end ( 2pm-ish) as there's tons of guys from SoCal that need to start their trek home.. There is apparently tractor museums you can go in, on the premises ( first year being held at location so don't know what's in them) Very low key and such, and most owners are older so not a shitshow of 20 somethings doing donuts.. This isn't my show i only go June 8-9th http://www.antiquepowerland.com/index.html http://www.antiquepowerland.com/html/calendar.html <<< calander,, It says Japanese vehicles but it's only Datsuns and older Nissans / Cedrics Really bad video i did in 2017(?) ,, there are about 30 or more cars behind where i started walking from and some that never really leave "camping" area all weekend Not sure what My son and i are driving this year yet,, but probably one of my usual 411s OR 410 project i am putting off because of bathroom remodel . and sons got a A10 2door project ( he normally drives A10 wagon) he was hoping to waddle down there in. He's behind on that as it's been so cold,,, and being a 23 year old he is easily distracted . Did any of that make sense ?? lol . 1 Quote
MARTS-PL310 Posted March 13, 2019 Author Posted March 13, 2019 Yes, I'm still in the Pacific NW. Interesting about the Oregon show, never been there. Too bad about the Canby situation. I'll look into the new venue some more and see if it could be worthwhile, or would I rather keep making progress in the garage? My car absolutely will not be complete. I'm beginning to think in terms of years to complete rather than weeks and months, and just be satisfied with making incremental progress. At some point in the near future the body will even have to be lifted off the frame to fully access the floor repair welding. I know what you mean about the cold. I go into my garage for just a few hours with at three or four layers of shirts, sweaters, etc. I keep most of my detail bare metal part fabrication collection inside the house to ward off flash rusting. We still have snow and ice mounds from four or more weeks ago that just won't quite disappear. 1 Quote
bananahamuck Posted March 13, 2019 Posted March 13, 2019 We still have mounds of snow, and neighbors with trees still have snow covering south ends of yards. We are out near Littlerock Like i mentioned ,, you should go even if your car is still apart.. i aint in need of meet-up or anything just go all secret squirrel.. I'm usually talking too in heated arguements with, guys i only get to see in person once a year. A dude named Hogie drives a NL320 ( working on a 312 wagon but it needs everything) and if it's nice Wayno drives either his NL320 or his U320,, and both those clowns would love to talk about 312/320 type vehicles.. I have an older brother that doesn't like going because people might talk to him,, lol. the only people he hates more than strangers,,, are family ,,, haha . Quote
RUNAMUCK Posted April 22, 2019 Posted April 22, 2019 Wow you have some mad skills! Even better that they're being put to use on such an elegant piece of automotive history. Quote
Gwagg Posted May 4, 2019 Posted May 4, 2019 Strong work. I have a 1962 datsun pl311 same body as the 310 and the rust is the same as yours. I would like to sale the car to you knowing you are the man for the project. Contact me a gwagg6734@gmail.com. or 1 406 371 3802. 1 Quote
MARTS-PL310 Posted July 11, 2019 Author Posted July 11, 2019 That sure would have been a nice parts car for me if I had storage. It may be too nice though to break it up. I've got my limited space, time and labor maxed out with one rusty Bluebird. I'm back to work at posting a bit more progress on the build page tonight. 61 Datsun Bluebird PL310 De-Rustification Project. Build: https://oldschool.co.nz/index.php?/topic/60264-marts-pl310-61-datsun-bluebird-sedan/ Quote
