KKtrips
Mofs Toyota Hiace/Holden
16 minutes ago, Nominal said:
What are you main radiator hoses like? Is there a spring in the bottom hose? It is possible that these can 'close up' under the pump suction.
Thanks for the articles. Will have a read through.
Main hoses are all good and brand new. Bottom hose doesn't need a spring as its pretty much metal corners that manu fabricated to get the hose to fit in. haha.
In a nutshell it seems that the radiator is doing it's job up to a certain point and then it just can't cope anymore.
BTW I have been flushing the system so currently has rad flush and water in the system (no coolant). Would the higher boiling point of the coolant help in this regard? (I think that heat is heat and even if it was coolant it would still be running too hot?)
Share this post
Link to post
Will try the pop bottle test!
Also reading about making the radiator a triple pass design may be a good way to go...
Will need to get one of those guns and actually measure how much it's reducing the temp right now.
Share this post
Link to post
Tested in some boiling water and it opened. Can see water moving when it gets to temp when rad cap is off.
I have gutted a thermostat which I will put in and take for a drive and see if makes a difference.
Share this post
Link to post
Has the overheating always been a problem? It seems like it might have started getting worse at some point?
Share this post
Link to post
So in your build thread, the link to this discussion thread has a picture of the engine/hoses/radiator that I can't seem to find in either threads to have a proper look. But what I'm getting at is
The top radiator hose looks like it goes up from the thermostat housing outlet, then down to the radiator. Making a high spot that will make an airlock. When you fill it have you/you need to bend the hose down at the thermostat end and work your way along the hose to the radiator end to work the air out. Top up and repeat until all the air is out. (Or change the hose for one of a flatter angle).
If it's just the angle I'm looking at it, and the hose is actually uphill to the radiator, then please disregard.
Share this post
Link to post
I got told it always ran hot which it did but it never actually overheated to the pump it steamed... but then it got worst after I/we replaced the timing gear so I obviously have fucked something.
Since then I have
Had radiator rodded.
Changed Thermostat
Changed Water Pump
Manu added shroud/fan (which it always needed as I didn't get much airflow going up hills)
New pipes.
Needless to say I'm at my wits end and if I don't sort it out before xmas I've just wasted alot of money as I won't get to go away in it.
Share this post
Link to post
Yeah. It goes up from thermostat to the radiator. It probably used to be the other way round, (so there are probably pictures of both!) but since manu put the shroud on, he lifted the rad about 3" at a guess.
Share this post
Link to post
If the ignition timing is out (too retarded) then you will get overheating. Also lean mixture can be a problem.
It seems you have looked at most of the usual things with the cooling system, so checking the tune would be adviseable.
Do you get detonation/what's the compression? In my 186 I have to run 95 fuel and even then have the timing backed off (retarded) a bit to stop it pinging.
Share this post
Link to post
4 minutes ago, Mof said:
Now I am confused, that picture isn't your van
LOL. Are you on about the picture at the top of this thread.. Cos yeah that isn't my van at all!
Share this post
Link to post
Had the ignition timing checked out by a timing light, mind you this was ages ago.
Unfortunely I am the wrong person to tell you if its pinging etc. Do you have any recommendations who to go to to get the fueling/timing checked etc? I do have a weber 32/36 which I am about to send to Weber specialist to get jetted/tuned and for the manifold to get a water jacket etc but I doubt i'll get to fit it before xmas as its bigger and probably needs modification to the engine bay lol.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
