Retro Posted November 13, 2014 Share Posted November 13, 2014 What a reasonable price for one of these, $100? Quote Link to comment Share on other sites More sharing options...
Retro Posted September 20, 2015 Share Posted September 20, 2015 heey guys, im trying to get the hunter going but just isnt working for me since im not that exprienced with the engine side of things! so i was just wondering if yous could help me, there is no spark, battery is charged and its not turning over! there is just a clicking sound when turning the key... whats wrong? Quote Link to comment Share on other sites More sharing options...
Beaver Posted September 20, 2015 Share Posted September 20, 2015 Starter solenoid by the sounds of it. Give the start motor a good tap with a hammer and try again Quote Link to comment Share on other sites More sharing options...
Retro Posted September 20, 2015 Share Posted September 20, 2015 cheers beaver Quote Link to comment Share on other sites More sharing options...
Retro Posted September 20, 2015 Share Posted September 20, 2015 well that didnt work out at all, anything else beaver? Quote Link to comment Share on other sites More sharing options...
Nominal Posted September 20, 2015 Share Posted September 20, 2015 Check battery cables are all good and clean and tightly bolted - both the power feel and earth cable. Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted September 20, 2015 Share Posted September 20, 2015 Tap it harder...? Check all the wires going to ya starter motor. Get a replacement starter. Insert. Quote Link to comment Share on other sites More sharing options...
kyteler Posted September 20, 2015 Share Posted September 20, 2015 Check your earth cable connections. Double check you battery has good voltage. I'd come over and take a look for you but it would have to be a weekend and I'll be away for the next few. Pull the starter motor off if you have to and bench test it. Not sure about the hunter but most older starters and solenoids and pretty easy to pull apart and have a nosey around. Check the commutator on the starter motor and the brushes are connecting fine, maybe get some very fine emery paper and give then a light tickle. I would be more inclined to believe it's still a voltage/battery/earth cable issue. Check all connections, disconnects, clean, scuff and reconnect to ensure they're getting the best possible connection. Quote Link to comment Share on other sites More sharing options...
Retro Posted November 19, 2015 Share Posted November 19, 2015 Im going to replace the starter on saturday and see if the old girl starts or not! Quote Link to comment Share on other sites More sharing options...
