jclape Posted June 24, 2013 Share Posted June 24, 2013 I was wondering if a 3SGTE engine is a direct bolt in to a mr2 mk1 I am looking to add a boosted motor or build one . If the 3SGTE fits though it will save me some work. Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 24, 2013 Share Posted June 24, 2013 No mate it is not bolt in, it has been done though. You will have a much easier time adding boost to a 4age/4agze. Quote Link to comment Share on other sites More sharing options...
jclape Posted June 24, 2013 Author Share Posted June 24, 2013 I just looked it up definitely out of my range of knowledge at this point. I am looking for a 4agze it looks like. at least the block to go from there. just confused on what I will need to make this build successful to many people with different opinions. Will the transmission hold. Quote Link to comment Share on other sites More sharing options...
Rookie Posted June 24, 2013 Share Posted June 24, 2013 Just buy a supercharged one and rip the supercharger off? Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 24, 2013 Share Posted June 24, 2013 There are plenty of 4age engines with up to and over 200kw with turbo setups in east west format so there should be plenty of info around. The C series transmission will take abit of abuse but you may want to convert to the bigger E series trans if you start braking C's. As rookie says if you find a 4agze that is the easiest starting point, they will take plenty of boost. The only thing really specific about the 4age short/long block is the pistons, so you can swap these into other 4ages and make something equally as strong. This depends what motors are easy to get for you locally? Start googling. Quote Link to comment Share on other sites More sharing options...
jclape Posted June 24, 2013 Author Share Posted June 24, 2013 is 1900 dollars expensive for a 4agze with 45000 miles on them. there are 2 on ebay Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 24, 2013 Share Posted June 24, 2013 Are you in the US? http://www.ebay.com/itm/Toyota-Corolla-Twin-Cam-Supercharged-Engine-LSD-Trans-Wiring-Ecu-JDM-4A-GZE-/390601609582?pt=Motors_Car_Truck_Parts_Accessories&hash=item5af1ab916e&vxp=mtr $1600 with gearbox and all, seems pretty sweet. Quote Link to comment Share on other sites More sharing options...
jclape Posted June 24, 2013 Author Share Posted June 24, 2013 yes I am in the US I didn't see this one thanks. Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 24, 2013 Share Posted June 24, 2013 Theres a bunch of imported motors on there around that price, you really can't go wrong for that money. Note the LSD will be a shit factory viscous and won't do much but its a good start. You already have a MR2? Quote Link to comment Share on other sites More sharing options...
jclape Posted June 24, 2013 Author Share Posted June 24, 2013 Yup I have a 1986 Toyota mr2 Its a remanufactured motor but its a N/A motor want something faster and that I can throw more power into. Quote Link to comment Share on other sites More sharing options...
kpr Posted June 24, 2013 Share Posted June 24, 2013 remanufactured as in rebuilt i take it? i'd piece together a turbo setup on current engine, rather than swapping it out for 4agze. but swapping in a 4agze will be easier. Quote Link to comment Share on other sites More sharing options...
jclape Posted June 24, 2013 Author Share Posted June 24, 2013 I meant rebuilt lol I am going to either buy a block and build a engine ground up or buy the 4agze and sell the super charger and use the rest with a turbo instead.. just figured I can drive it while I rebuild a new improved motor and slap it in when finished. Looking to do it the easiest way possible honestly. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted June 24, 2013 Share Posted June 24, 2013 How well does a turbo run with a factory ZE ECU? Quote Link to comment Share on other sites More sharing options...
jclape Posted June 24, 2013 Author Share Posted June 24, 2013 not sure I have read the N/A ecu is good for 15lbs of boost also read that the super ecu sucks so I don't know who to believe Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 24, 2013 Share Posted June 24, 2013 remanufactured as in rebuilt i take it? i'd piece together a turbo setup on current engine, rather than swapping it out for 4agze. but swapping in a 4agze will be easier. Would just be a blue top though? if you are meaning just boost the fuck out of the stock bluetop I heartily approve. Otherwise by the time he tracks down a large big end crank, rods and ZE pistons its probably going to be cheaper and easier to buy a $1600 ZE? with E series box, charger and loom/ecu its actually a hell of a deal for the USA. Considering a silver top with a gearbox is $1200 lol Quote Link to comment Share on other sites More sharing options...
kpr Posted June 24, 2013 Share Posted June 24, 2013 yeh, i mean turbo current engine. if its fresh rebuild, no reason why it can't make a reliable 150kw or so at the wheels. aftermarket ecu and good tune is a must though. c series box should be fine also. ran over 200kw through mine without any drama. although that was in a lighter fwd chassis ze ecu will run a turbo setup ok. the map sensor version does some weird stuff though. the older afm setup is spose to work better. na ecu is good for no boost. there are some dodgy tricks to make then run with some boost. but if you want the it to be hassle free(not megasquirt), last and make good power. aftermarket + good tuner is where its at Quote Link to comment Share on other sites More sharing options...
jclape Posted June 24, 2013 Author Share Posted June 24, 2013 so buying a complete motor is definitely the way to go .. also are you saying not to buy a mega squirt ecu or are they ok? Quote Link to comment Share on other sites More sharing options...
Roman Posted June 24, 2013 Share Posted June 24, 2013 Buy everything you think you will need, *before* you start pulling your car apart, and put the turbo on etc while it's on an engine stand. Then try swap everything over in one big hit... You wont though as you'll have unexpected problems. The leading cause of project demotivation is having it sit there for months on end without being able to drive it. Even if your project is as straight forward as possible (even just gze swap) you're still going to be held up by various things and have the car off the road for a while, if it's the first time youv'e done something like this. Since it's likely that you would have to spend $$$ to get an engineer to check over your car and what not, have you considered just buying a factory supercharged AW11 if they're available where you are? Rather than swapping a grunty motor but still having a weaksauce gearbox etc it comes with all of the good stuff with zero hassle. 1 Quote Link to comment Share on other sites More sharing options...
jclape Posted June 24, 2013 Author Share Posted June 24, 2013 I can buy a complete engine on ebay for 1800 with the super charger . I will have the engine on a engine stand then I can do a rebuild on it from there while I drive the car . It will go up as soon as the first snow flake flies any way . I will work on the engine over winter and hopfully by spring ready to put it in the car . I shouldn't have to do to much to the engine they say it only has around 50,000 miles on it so it should be good . will compression check the cylinders. should I have to replace anything on the motor that may cause a issue with the added HP? also comes with the transmission. Quote Link to comment Share on other sites More sharing options...
jclape Posted June 27, 2013 Author Share Posted June 27, 2013 is there anything I should upgrade like oil pump or anything like that from the 4agze engine. should I change the pistons to a lower compression piston or better quality. Quote Link to comment Share on other sites More sharing options...
