I can buy a complete engine on ebay for 1800 with the super charger . I will have the engine on a engine stand then I can do a rebuild on it from there while I drive the car . It will go up as soon as the first snow flake flies any way . I will work on the engine over winter and hopfully by spring ready to put it in the car . I shouldn't have to do to much to the engine they say it only has around 50,000 miles on it so it should be good . will compression check the cylinders. should I have to replace anything on the motor that may cause a issue with the added HP? also comes with the transmission.
