eke_zetec_RWD Posted January 21, 2013 Share Posted January 21, 2013 so i need a new turbo to extend my power levels to about 240kw atw on my turbo pinto. (currently 200kw atw) it currently uses a IHI vf36 which is a twin scroll bb turbo used on spec c wrx sti, so i want to stick to this configuration as everything it set up around this. i can pick from kinugawa tdo5 18g tdo5 20g tdo6 20g tdo6 25g tdo6 60-1 and in each i think i can get in either 8cm^2 and 10cm^2 exhaust housings. i currently get 20psi boost at about 3600 rpm and obvisously i would love to keep that but i realise i will loose a few hundred rpm. also currently on 17ish psi seems to be max efficiency for the vf36, above that at high rpm power doesent really change. so i think a more efficent turbo should mean more power at higher rpms? whats your recommendations and please include your reasoning and experiences. cheers Jason Quote Link to comment Share on other sites More sharing options...
JoKer Posted January 21, 2013 Share Posted January 21, 2013 reading nothing good about them king ppl on ClubSUB TD05 20G is my pick, anything bigger will be detrimental on a 2L Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 21, 2013 Author Share Posted January 21, 2013 i cant find anything bad about them on the nets? other than haters that havnt actially used them. but im thinking tdo5 20g also Quote Link to comment Share on other sites More sharing options...
JoKer Posted January 21, 2013 Share Posted January 21, 2013 if you can read it without logging in try here http://www.clubsub.o...ic,35011.0.html links thru to NASIOC and another thread on SDU/Australia I have a 05 in my shed if you wanna check it out on ur way hm (offa Mitsi/evo tho) Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 21, 2013 Author Share Posted January 21, 2013 if you can read it without logging in try here http://www.clubsub.o...ic,35011.0.html links thru to NASIOC and another thread on SDU/Australia I have a 05 in my shed if you wanna check it out on ur way hm (offa Mitsi/evo tho) nothing bad on those links worthy of listening too.... Quote Link to comment Share on other sites More sharing options...
JoKer Posted January 21, 2013 Share Posted January 21, 2013 sweet : i never even bothered looking #aintcare : just appeared to not be in good light just waiting to see if Murch takes the bait mind you Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted January 21, 2013 Share Posted January 21, 2013 TD06 20G will flow that easily, but you'll get a bunch more lag. TD05 20G will be the best of the bunch to use, unsure of how well your head flows (Pretty well I'm guessing) but it ought to be able to give you 240kw if you lean on it. Best thing about the TD series is they're cheap to rebuild. Quote Link to comment Share on other sites More sharing options...
mjrstar Posted January 21, 2013 Share Posted January 21, 2013 I run a evo 9 Td05 hr but with td06 20g wheels and 10.5 ex housing and its great.. It made a solid 230 kw at 18 psi and had previously only been road tuned. Mazda will get the same turbo... Oh an it makes full boost at around 3200 rpm. Unsure of how subaru turbos compare sorry. Quote Link to comment Share on other sites More sharing options...
fuel Posted January 22, 2013 Share Posted January 22, 2013 I have a TD05-20G on my VR-4 - it's just the factory TD05 with the 16G wheel binned and 20G wheel and ported compressor housing swapped on. Gave the turbine an 8deg back cut though to help with the flow. I didn't notice much of a lag increase over the standard 16G - full boost comes on around 3200-3500rpms depending on gear. I'm only running 15psi though. I would look at doing the Evo4+ TD05HRA twin scroll hot side with a 20G compressor/housing upgrade. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 22, 2013 Author Share Posted January 22, 2013 Td05 20g is sounding the go, will it hit 240kw tho? Quote Link to comment Share on other sites More sharing options...
fuel Posted January 22, 2013 Share Posted January 22, 2013 should do the VR-4 guys somehow get that power out of 16G TD05s so from a 20G it shouldn't be too much of an ask - it's probably reaching close to its upper efficiency though, probably more the hot-side rather than the cold-side which is why I back cut mine to help. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 22, 2013 Author Share Posted January 22, 2013 Sweet. Anyone bought a kinagawa turbo off eBay and got it sent over? They about 500 cheaper than the local suppliers. Quote Link to comment Share on other sites More sharing options...
fuel Posted January 22, 2013 Share Posted January 22, 2013 I've bought a genuine MHI rebuild kit along with an aftermarket 20G wheel and compressor housing to suit from him - took about a week to arrive and his service was good. He must drop-ship because the goods were sent direct from China/Taiwan rather than Japan. Quote Link to comment Share on other sites More sharing options...
MRWEST Posted January 22, 2013 Share Posted January 22, 2013 yup a mate has bought one off ebay and got it back here for about 900 i think. Quote Link to comment Share on other sites More sharing options...
mjrstar Posted January 22, 2013 Share Posted January 22, 2013 Have you looked at building up a good oem core with oversize wheels rather than a kinugawa unit? I know which i would rather have.. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted January 22, 2013 Share Posted January 22, 2013 Have you looked at building up a good oem core with oversize wheels rather than a kinugawa unit? I know which i would rather have.. This guy Steve Murch- Motor Sport Engineering seems to mention similar occasionly and might be worth chatting to http://www.facebook....6937679?fref=ts Seems like he does some cool stuff Uploaded with ImageShack.us Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted January 22, 2013 Share Posted January 22, 2013 Have you looked at building up a good oem core with oversize wheels rather than a kinugawa unit? I know which i would rather have.. this /\ and murch is the man when it comes to turbos! although he'll try and talk you into a holset, cause there cheap/reliable and make decent power i run a td05hra-16g in 10.5 hot side and i get 220kw on 17psi...(on sr20) with decent cams my tuner said 245kw shouldn't be a problem, twin scroll fucking rules!! have heard the 20g wheels tent to choke abit with the td05 hot side, but haven't tried it myself Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 22, 2013 Author Share Posted January 22, 2013 I don't think my housings are thick/big enough to accommodate new bigger wheels and as far as I know new bearings Arnt available to rebuild my core. I'm open to look at other brands but apart from I think hks or some expensive as brand I can't find any twin scrolls that suit my manifold. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 22, 2013 Author Share Posted January 22, 2013 Chris did u read that lol Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted January 22, 2013 Share Posted January 22, 2013 I have no idea what you are talking about Quote Link to comment Share on other sites More sharing options...
