shizzl Posted November 1, 2012 Share Posted November 1, 2012 so as you may know i sold the cortina.. in a way i regret but then again i dont....not when ive gone and got this quite cheap.. was all red with a black arse when i got it,however it was living in bluff, so it had some sub paint surface rust,this had to be sorted asap, so i cut it back and adressed any shit areas, luckily theres no rust holes etc... so i took it to work and painted it in a flat green.....im stoked with the colour... im picking up some 32" KL71 kumhos next weekend, will lift it a little more just for shit n giggles... and interestingly this has a set of extractors fitted, never knew you could get them for these,so double stoke for poke.. drives good, although the clutch is nearly right out so will put a new clutch in it soon, and make up a winch bar,and put a rollbar on the deck.... Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Quote Link to comment Share on other sites More sharing options...
P_Star Posted November 1, 2012 Share Posted November 1, 2012 Looks tough! Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted November 1, 2012 Share Posted November 1, 2012 interested to see how these things fare! not many are used for anything but generic ute duties. awesome! Quote Link to comment Share on other sites More sharing options...
kyteler Posted November 1, 2012 Share Posted November 1, 2012 I wondered if that was you this morning. Quote Link to comment Share on other sites More sharing options...
shizzl Posted November 2, 2012 Author Share Posted November 2, 2012 yeah it was...i didnt see you till the last second.. Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted November 2, 2012 Share Posted November 2, 2012 fuck yeah, that's tough. no reason why it won't be as good as anything else off road- just harder to get aftermarket parts for Quote Link to comment Share on other sites More sharing options...
shizzl Posted November 2, 2012 Author Share Posted November 2, 2012 i used to have a marvie, exactly the same but a hard body,and a bit heavier...was allright offroad,just as good if not better than my old ln130 surf... keen to get this dirty asap.... no point yet as i havent even got round to buying a rifle Quote Link to comment Share on other sites More sharing options...
shizzl Posted November 3, 2012 Author Share Posted November 3, 2012 adjusted the rear brakes today and checked the front pads, pedal was quite low and the left rear locks up too easy.. it has new shoes and pads all round....win however the rears were nowhere near close to being adjusted. so got them adjusted up and the pedal is mint... hopefully the rears will be equalised better and not lock up... would be helpfull seeing as im going down the kilmogs tomorrow at o'dark oclock... Quote Link to comment Share on other sites More sharing options...
shizzl Posted November 3, 2012 Author Share Posted November 3, 2012 Displacement, cc 2605 Engine model G6 Max.power (Net), kw(PS)/rpm 120 ps (88.26 kw) / 4500 rpm Max.torque(Net), N*m(kg*m)/rpm 20.6 kg*m (202.02 N*m) / 3500 rpm Power density 14.5 Engine type Water cooling serial 4 cylinder OHC12 valve Engine information Fuel system EGI (electronic gasoline injection) Turbocharger No Fuel type Unleaded regular gasoline LEV system (Low emission vehicle) No Compression ratio 8.4 Bore, mm 92 Stroke, mm 98 Final gear ratio Fuel consumption at 10-15 modes, l/100km 13.8 ugh, low comp, boost needed???????? Quote Link to comment Share on other sites More sharing options...
maloney Posted November 16, 2012 Share Posted November 16, 2012 they a quite good offroad we had 1 exactly the same needed to raise it up a bit as it bellyd out quite easy be very careful as the front hubs bend quite easy wen goin offroad we went thru heaps lol Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted November 16, 2012 Share Posted November 16, 2012 does this one's gearbox lock up the centre diff? I'm told the wagon style ones don't, and end up stuck as soon as you get a bit of wheel slip through one wheel. Quote Link to comment Share on other sites More sharing options...
shizzl Posted November 18, 2012 Author Share Posted November 18, 2012 our marvie was all good offroad on muddy tracks ae...i wouldve expected to get stuck but it kept on going... if i can find someone with a snatch strap(elfin) id go get it stuck and see what its doing.. did a oil change yesterday with some promar...all lifter noise has gone now, still has exhaust leak,grrr... and its running rich....the temp gauge barely reads,so im guessng its either due to faulty sender or thermostat is gay. Quote Link to comment Share on other sites More sharing options...
shizzl Posted November 18, 2012 Author Share Posted November 18, 2012 was gonna splash out on some good tyres...however trademe got the better of me and i bought a saiga 308 semi auto rifle instead...its basically a variant of a AK..hells yes! 2 Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted November 18, 2012 Share Posted November 18, 2012 should be able to tell if the centre diff locks up by driving it on tar seal hah. badass. Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted November 18, 2012 Share Posted November 18, 2012 was gonna splash out on some good tyres...however trademe got the better of me and i bought a saiga 308 semi auto rifle instead...its basically a variant of a AK..hells yes! hold your thumb up so the bolt doesn't travel far enough to latch.... and keep the trigger pulled 1 Quote Link to comment Share on other sites More sharing options...
shizzl Posted November 18, 2012 Author Share Posted November 18, 2012 maori auto? Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted November 18, 2012 Share Posted November 18, 2012 exactly... SO SO SO AWESOME Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted November 18, 2012 Share Posted November 18, 2012 isnt there something you can do with a rubber band? bump firing or something that makes it basically an auto? Quote Link to comment Share on other sites More sharing options...
shizzl Posted November 18, 2012 Author Share Posted November 18, 2012 double tap isnt too slow...a mate has many rifles of various awesomness and has a couple of these anyway.. he also knows alot of tricks with most rifles, so itll get a tickle up... no pics will be taken of it except in legal form,lol... jokes,itll stay legal Quote Link to comment Share on other sites More sharing options...
Raizer Posted November 19, 2012 Share Posted November 19, 2012 Just out of interest how much did the Siaga set you back? Going to convert yours to forward trigger/pistol grip? Quote Link to comment Share on other sites More sharing options...
