yoeddynz Posted September 2, 2013 Share Posted September 2, 2013 You photoshopped that cat onto the bonnet yeah?- otherwise did you use magic mirrors and string? Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted September 2, 2013 Author Share Posted September 2, 2013 I honestly don't know how the cat even got up there.. I just turned around and she was putting on a tightrope act. There isn't much to stand on up there!! Quote Link to comment Share on other sites More sharing options...
BDA780 Posted September 9, 2013 Share Posted September 9, 2013 That wax buck is sweet. Â Whats the internal surface finish like? This may help you if your looking to buy a 3D Printer: http://www.3ders.org/pricecompare/3dprinters/ Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted September 9, 2013 Author Share Posted September 9, 2013 Cheers man. Surface finish on inside is good- but I didn't put much effort into the wax part or inside of cardboard mould. If I'd cared I could have shaved the wax with a knife and achieved much better results. The sides of the rectangle end bow in slightly due to the shrinkage of the wax- in reality this is no problem but its not aesthetically pleasing. Wax was the easiest way to do it as it is not a shape that will pop out of a mould easily unless its two piece or I make two halfs of the transition and join afterward. OR other option is just making the piece so that it can be demoulded easily- I just wanted to play with that unfolding software! Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted September 9, 2013 Author Share Posted September 9, 2013 Also- highly recommend using lavender scented candles- smells lovely during the process 2 Quote Link to comment Share on other sites More sharing options...
MRWEST Posted July 6, 2014 Share Posted July 6, 2014 same spacer as what im running, what box you running? Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted July 11, 2014 Author Share Posted July 11, 2014 Power glide. Supposedly built to take 800 horsies. May have been 600 and memory is playing tricks.. Can not recall 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted July 11, 2014 Author Share Posted July 11, 2014 Trying to find an sfi flywheel in NZ is proving a bit difficult. Might have to order from summit or jegs. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted September 16, 2014 Share Posted September 16, 2014 Awww shit. Totally forgot about picking up your Au fans au. Want me to grab them still, or did you want to personally collect them when you're here? Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted September 16, 2014 Share Posted September 16, 2014 The auto speed controller is great , it doesn't say in the instructions but it holds the settings when powered off . Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted September 16, 2014 Author Share Posted September 16, 2014 Awww shit. Totally forgot about picking up your Au fans au. Want me to grab them still, or did you want to personally collect them when you're here? You should totes grab them thanks bro! He mailed today to say hes seen payment etc. Hardly urgent though. Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted September 16, 2014 Author Share Posted September 16, 2014 The auto speed controller is great , it doesn't say in the instructions but it holds the settings when powered off .Just to be clear- it only switches a relay...no actual speed control. But yes very good units! I was tempted to get two and have the fans staged with the second one coming on like ten degrees after the first.... But that's putting way to much thought into things. Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted September 16, 2014 Share Posted September 16, 2014 Yeah ,I'm using the same controller on my Pajero . http://imageshack.com/i/10jxt9j Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted September 16, 2014 Author Share Posted September 16, 2014 Nice. How did you mount your sensor? Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted September 16, 2014 Share Posted September 16, 2014 I got an old temp sender and removed the guts and just glued the sensor into it. I did find on eBay a sensor with a thread that matches the controller one but has a thread . It was only $5 . I didn't use it as the thread turned out to be an odd size , you're welcome to it f you want it Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted September 16, 2014 Author Share Posted September 16, 2014 Thanks man. I think I'll Di the same as you as I have some old ones here too. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted September 18, 2014 Share Posted September 18, 2014 Drop tank for sure Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted September 18, 2014 Author Share Posted September 18, 2014 Yeah I think so too. I'll weld mounts to the top and bolt it to the underside I think...And just cut a hole for the filler. It won't look as cool though! I need to change all the bolts to stainless too Quote Link to comment Share on other sites More sharing options...
