kkatl Posted October 8, 2012 Share Posted October 8, 2012 hi peeps im going down the turbo track with my 711m crossflow its bored to .060 thou, the cranks stuffed so i need a new one. im going to get forged pistons is this all i need? or do i need rods aswell? what type of rods and pistons are sufficient and what type of crank? im getting the o-rings in the block aswell. im expecting about 150-200 hp if possible. i need to lower compresssion so i have an old head that has the original combustion chamber in the head, so i can run flat top pistons by matching the combustion chamber and making a spacer plate with the matched combustion chambers cut into it. also im getting the largest valves including port and polishing. many thanks Quote Link to comment Share on other sites More sharing options...
bigmatt4 Posted October 8, 2012 Share Posted October 8, 2012 nissan l16 or l18 crank are a factory steel crankshaft and they fit with a bit of machining to block and crank Quote Link to comment Share on other sites More sharing options...
kkatl Posted October 8, 2012 Author Share Posted October 8, 2012 ok sweet thanks heaps mate, il have a search for those at the wreckers next time im out. Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 8, 2012 Share Posted October 8, 2012 By bit of machining he means about $1000 worth. And yea, you can get forged pistons and h beam rods for them, all spendy stuff. You should get more than 200hp as you can nearly get that NA. Quote Link to comment Share on other sites More sharing options...
GT_Escortina Posted October 9, 2012 Share Posted October 9, 2012 hi peepsim going down the turbo track with my 711m crossflow its bored to .060 thou, the cranks stuffed so i need a new one. im going to get forged pistons is this all i need? or do i need rods aswell? what type of rods and pistons are sufficient and what type of crank? im getting the o-rings in the block aswell. im expecting about 150-200 hp if possible. i need to lower compresssion so i have an old head that has the original combustion chamber in the head, so i can run flat top pistons by matching the combustion chamber and making a spacer plate with the matched combustion chambers cut into it. also im getting the largest valves including port and polishing. many thanks http://www.turbosport.co.uk/showthread. ... bo-from-SA http://www.classic-ford.org/cfp/tm.aspx?m=35937&mpage=1 Quote Link to comment Share on other sites More sharing options...
Sorensin Posted October 9, 2012 Share Posted October 9, 2012 probably want to think about getting the block sleeved to if your going to run any real boost. +1 to the $1000 of machining, i started looking at it got a couple quotes, dropped the idea. Quote Link to comment Share on other sites More sharing options...
J-W-G Posted October 9, 2012 Share Posted October 9, 2012 Doubt youll ever hit 200hp. That number and the kent dont like one another from what ive seen. But yep some low compression pistons the standard ones for 1600 are like 8.5 or 9.5? you could run mild boost on stock internals Id be looking at forged low comp pistons, rods and crank if you want serious power if you have thousands to spend on machining, porting and components. Id say youd be looking at 130 to 190 bhp for a road going kent turbo although ive only seen them putting out 150 max Id look at injection too unless you want to have a suck through carb set up Quote Link to comment Share on other sites More sharing options...
shaneo Posted October 9, 2012 Share Posted October 9, 2012 I'm starting to look at doing a turbo as well already have a L18 crank lyning around but just want to get 6 to 8 pound boost my mates thing it will be a faster set up from what I have I do plan on a brand new carb and having a blow though. The tourqe is meant to be mean with the turbo Quote Link to comment Share on other sites More sharing options...
Horse25 Posted October 9, 2012 Share Posted October 9, 2012 i found this thread here pretty interesting > http://www.turbosport.co.uk/showthread. ... ent-build!! Quote Link to comment Share on other sites More sharing options...
peteretep Posted October 9, 2012 Share Posted October 9, 2012 that thread sucks because the guy never came back with what/if anything happened Quote Link to comment Share on other sites More sharing options...
J-W-G Posted October 9, 2012 Share Posted October 9, 2012 Some stuff for you http://www.turbosport.co.uk/showthread. ... w-worth-it Quote Link to comment Share on other sites More sharing options...
J-W-G Posted October 15, 2012 Share Posted October 15, 2012 http://www.turbosport.co.uk/showthread.php?233254-Big-bhp-Xflow Read that mate the guys apparently made a few kent turbos with good power Quote Link to comment Share on other sites More sharing options...
