sheepers Posted June 25, 2012 Share Posted June 25, 2012 the injector pump on the land cruiser is leaking a bit from time to time, it appears to be coming from around the top flange but thats far from certain. some times it will actually drip off the bottom of the pump and sometimes its a bit wet and diesely around the pump. the motor is a 3B toyota motor, ummm, can't tell you much else. how do i remedy this situation???? thanks all. sheepers. Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 25, 2012 Share Posted June 25, 2012 get a diesel/4x4 workshop to replace the seals...not overly expensive Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted June 25, 2012 Share Posted June 25, 2012 It can be very very expensive if they want to service the whole pump, which they will prolly try doing. I suggest signing up to ore.co.nz and asking there Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 25, 2012 Share Posted June 25, 2012 we had the seals in our 4x4 done for $400.. most can be done without taking the pump off..depending whats leaking.. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 25, 2012 Share Posted June 25, 2012 I've heard of it getting really expensive also. Buy kit and fix yourself? Or repower with supercharged Lexus V8? Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 25, 2012 Share Posted June 25, 2012 could also turn out really expensive if you try to crank open a diesel injection pump yourself and getting shit inside it.. i know i wouldnt try it lol you wont know what itll cost untill you ask them Quote Link to comment Share on other sites More sharing options...
Evan Posted June 25, 2012 Share Posted June 25, 2012 Or repower with a 2m Quote Link to comment Share on other sites More sharing options...
Valiant Posted June 25, 2012 Share Posted June 25, 2012 Toyota ones often leak around the top there is a shaped o ring and an o ring on the throttle shaft. It is quite easy to replace them both, just mark where the throttle lever is on the shaft before you pull it appart. You can get the parts from diesel repair shops they cost about $10 from memory Quote Link to comment Share on other sites More sharing options...
sheepers Posted June 25, 2012 Author Share Posted June 25, 2012 thanks alot guys. ill do some more digging about the o ring and the shaft seal, from what i can see this is the place its leaking from so it may very well fix it. choice. sheepers. Quote Link to comment Share on other sites More sharing options...
