Beaver Posted July 28, 2012 Share Posted July 28, 2012 185/60/13. will look fine. Quote Link to comment Share on other sites More sharing options...
camo_78 Posted July 29, 2012 Author Share Posted July 29, 2012 i have a pair of 13x6 spitties that are a very similar offset to my modgies with BFG radial T/As on them in 195/60 13 sizing.can put 4 people in the sport which sits it on bumpstops(joys of compressies ) and they dont rub.admittedly i did have to roll the lip up to do so but the sidewall sits nice n flush with the guard lip .i would get a pic but its currently on axlestands after i popped an axle in the locked diff PS:hit to the head would have induced i few expletives i suspect?? Quote Link to comment Share on other sites More sharing options...
shizzl Posted July 30, 2012 Share Posted July 30, 2012 doh,rain gets into the car...dripping from the dash somewhere...must investigate.. also theres a vibration only in 1st and 2nd....i have a feeling the diff is on the way out.. i know its not the box cos its coming from the back somewhere,and i know that the ujs and rubber components of the driveshaft are sweet.... but my biggest erk is the water temp is only getting to 50degree c.... im guessing theres no thermostat in it.. so no heater,it does get luke warm so im guessing that if it got to 85degree the heater would be sweet.... Quote Link to comment Share on other sites More sharing options...
camo_78 Posted July 30, 2012 Author Share Posted July 30, 2012 doh,rain gets into the car...dripping from the dash somewhere...must investigate..also theres a vibration only in 1st and 2nd....i have a feeling the diff is on the way out.. i know its not the box cos its coming from the back somewhere,and i know that the ujs and rubber components of the driveshaft are sweet.... but my biggest erk is the water temp is only getting to 50degree c.... im guessing theres no thermostat in it.. so no heater,it does get luke warm so im guessing that if it got to 85degree the heater would be sweet.... check foam gaskets under the heaterbox in engine bay,thats where the sport leaks water in Quote Link to comment Share on other sites More sharing options...
shizzl Posted July 30, 2012 Share Posted July 30, 2012 i take it the water gets in through that vent in the cowl panel,then into the heater box?? Quote Link to comment Share on other sites More sharing options...
camo_78 Posted July 31, 2012 Author Share Posted July 31, 2012 i take it the water gets in through that vent in the cowl panel,then into the heater box?? i suspect its the shape of the metal behind the heater box(think 1/4 pipe vert ramp for skateboarding),water runs straight down it,hits curve and gets fired straight under the heaterbox to where the gaskets are Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 31, 2012 Share Posted July 31, 2012 Saw you tonight at the Elles Road/Bluff Highway intersection, heading south. I was heading north in the Sunny. Quote Link to comment Share on other sites More sharing options...
shizzl Posted July 31, 2012 Share Posted July 31, 2012 haha saw you too then...OS spotted! lol Quote Link to comment Share on other sites More sharing options...
shizzl Posted August 4, 2012 Share Posted August 4, 2012 was gona work on the cortina today but thought i better investigate the oil drips that have started appearing on the suby... took the left rocker cover off and a small corner is missing from the RCG groove,so its been weeping from there,id say a stone has got at it...the cams etc look pristene..... so on the hunt for a left rocker cover for a 96ish gtb.... enough to piss me off and lose any motivation to work on cars this weekend... Quote Link to comment Share on other sites More sharing options...
felixx Posted August 4, 2012 Share Posted August 4, 2012 kneadit? or some other expoxy putty? It will do the job fine. I used it to fill a hole on the sump of a 3 wheeler in 1994. Sold the bike this year, it was still fine Quote Link to comment Share on other sites More sharing options...
shizzl Posted August 4, 2012 Share Posted August 4, 2012 normally im so rangi that i would use kneadit for it,but i think it would need to be perfect cos its the point that they all start to leak... ive used kneadit on manifolds before,totally underated product,right up there with duct tape,cableties and body filler.. Quote Link to comment Share on other sites More sharing options...
camo_78 Posted August 4, 2012 Author Share Posted August 4, 2012 ive got a couple of subi motors lying around,do you know if GT rocker/cam covers will fit a GTB motor??this is slightly odd though as we both own cortinas and GTBs,lmao Quote Link to comment Share on other sites More sharing options...
shizzl Posted August 4, 2012 Share Posted August 4, 2012 yup,were both suckers for punishment...dont tell me that your 32 aswell or ill stab you in the face with a soldering iron,lol STOP COPYING ME!!! hahaha Quote Link to comment Share on other sites More sharing options...
camo_78 Posted August 4, 2012 Author Share Posted August 4, 2012 yup,were both suckers for punishment...dont tell me that your 32 aswell or ill stab you in the face with a soldering iron,lolSTOP COPYING ME!!! hahaha got that right,lmao.and nope,26 with a goatee about 5 inches long,lmao. and im not copying,MY gtb is rear wheel drive Quote Link to comment Share on other sites More sharing options...
camo_78 Posted August 4, 2012 Author Share Posted August 4, 2012 your gtb isnt green is it??? Quote Link to comment Share on other sites More sharing options...
Raizer Posted August 4, 2012 Share Posted August 4, 2012 GT cam covers will fit GTB engines, I just can't remember if they change for the different coil setups. Quote Link to comment Share on other sites More sharing options...
camo_78 Posted August 4, 2012 Author Share Posted August 4, 2012 GT cam covers will fit GTB engines, I just can't remember if they change for the different coil setups. they do,ive bolted GTB coils into GT motors and vice versa.so shizzl,i got a couple of covers up here if you want them Quote Link to comment Share on other sites More sharing options...
shizzl Posted August 4, 2012 Share Posted August 4, 2012 my gtb is green when it goes through cow shit...lol which it hasnt... yeah and mines auto *stink eyes*.... i enjoy auto though cos you can eat BK on the move piece of piss rather than trying to juggle the steering wheel with ya knees,change gear with ya elbow while holding a burger in one hand,fries between ya legs and drink in the other hand.. eating in is easier, or go auto...lol...and i have done all of the above Quote Link to comment Share on other sites More sharing options...
camo_78 Posted August 4, 2012 Author Share Posted August 4, 2012 lmao,what colour is it normally?? and mine was originally an auto,i converted it to manual using a 94 wrx box that had the rwd conversion already.will be on motor #3 when i sawp them over :/ Quote Link to comment Share on other sites More sharing options...
shizzl Posted August 4, 2012 Share Posted August 4, 2012 its silver...amazingly its still got billys in it..they usually poke out,but these ride pretty sweet. anyway, i wouldve liked to get the heater box and thermostat housing off the tina this weekend... might look at resealing the windscreen before i fuck with the heater unit...but the thermostat needs investigating,cos it needs to get to temp so the choke works properly,and i want some heat on my feet..lol and i really need to get the lip on the guards sorted on the back.... Quote Link to comment Share on other sites More sharing options...
