What Oil pressure for turbo bearings?
yoeddynz
I just read in a read about turbo installations that most turbos only require very little oil pressure. Like about 10psi? Some turbo feed lines have a restrictor built in to keep the pressure in check.
I am wondering about this. my setup is draw through and if my turbo is seeing too high oil pressure then when my throttle is shut then this will only assist in oil wanting to get sucked past the seals by the vacuum?
Get a one from this joker!
http://www.ebay.com.au/itm/Turbo-Oil-Fe ... 852wt_1185
Good quality and can do you any custom combo you require.
Fitted 1.5mm restrict-or each end after my pressure blew a seal and seems to have resolved it. Escorts allot quicker not sunning on oil too :)
Oh and the stuff he sends is 'kinugawa' which is apparently quite good. Even gave me a spare fitting.
cool- i'll look at my feed line tomorrow and check that it doesnt already have a restrictor in it. My car does use oil- 1 litre over the 1800 km trip just done so not that bad. Also some leaks from the sump etc and I lose some from open breather too.
I did increase the oil pressure by modifying the regs when i rebuilt the engine so if my turbo seals are tired it must be best not it over feed it eh?
prob wrong but i have always thought restrictors slowed the flow of the oil but the pressure stayed the same.
i dont see how making the hole smaller reduces pressure, if anything it increases it.
Think of putting your finger over the end of a hose, more pressure but way less flow.
Increased pressure will increase the flow through a restriction. However decreasing the restriction will decrease pressure but increase flow through it.
If you are electronicly minded, it is the same as a resistor.
The turbo itself is a restriction to the oil. The bearings have a very fine clearance, and the oil pump slams out 50odd psi depending on many things.
Fed direct, there would be 50psi of oil at the turbo bearings (assuming they are not fucked / leaking).
A restriction in the line to the turbo limits the amount of oil that can get past. As such, the turbo will be getting less oil pumped through it, but also at less pressure. As the turbo does not need 50psi and a shittonne of flow this is all G.
More or less.
what yowzer siad . if you mash too much in there to the point were the return cant cope is just bails out the turbine seal . which is very much like a piston ring and as such does not cope with constant positive pressure very well .
trust me i know :lol: had a truck with its breath blocked and the turbo was the weakest link . that = entire road covered in white smoke :lol:
I think my turbo has the old style carbon seal which is much better suited to draw through turbos. The car doesn't seem to blow any blue smoke but I just wasn't sure if I may have been over feeding it. I think I will still make a little tee that I can screw a pressure gauge into.
Just had mine oil lines off lastnight, and its got a 2mm hole for my journal bearing turbo. Steve Murch explained it all to me in really simple terms, now I can't remember any of it... something like it doesn't need any massive pressure at all, just a constant oil supply for the bearing to float on and it wasn't the pressure which kills the seals but the volume going passed them... probably way off there though... Short answer was just put a restrictor on.
First turbo I put on shat itself with oil coming out anywhere it could, second turbo I fitted a restrictor and its been fine since.
I've got a brass fitting which goes directly into the turbo core, which the oil line connects to. Filled the centre of the brass fitting with braising, then drilled the hole through it... simple as
yea journal bearing turbos just need a constant trickle to give the bearings a film to run on, and BB turbos only need a constant drip to keep them lubed
in race cars where you have high oil pressure you would normally fit a restrictor at the feed from the block and then a gauge in the line to check it doesn't go really high with sustained high rev's, then check on the dyno, and fit a smaller or multiple restrictors reducing the flow and altering the pressure
i killed a hks t28 turbo on one of my early engines, i went from a factory t28 BB to a hks BB, thinking the restrictor would be in the line (and seeing the 2mm one in the banjo) i thought it would be sweet, 700k's later dead turbo, only to find out when nissan got garrett to produce the t28 they requested the restrictor be fitted on the inlet of the turbo, however hks did not stipulate this and requires external 1mm restrictor, im still sour about that turbo!! damn you HKS!
Hmmmmmm. I wonder if other turbo companies will head this way?
I must check my feed line ASAP (not now..it's cold outside and sitting in front of fire place is nicer than being under bonnet)
My car uses more oil when town driving ie start stop, waiting at intersections. It's not blowing blue smoke but if the pressure is to high then it is most likely getting a little past the seals at idle. Plus if so then that may be one reason, on top of the over rich idle setting, that my wideband sees rich mixture? Would extra oil getting burned raise the reading?
