burrowssj Posted April 24, 2012 Share Posted April 24, 2012 so the conversion has begun. Any tips on aligning the clutch? I don't have the tool.Are these still available for old cars? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 24, 2012 Share Posted April 24, 2012 Got a stuffed matching gearbox lying around? Quote Link to comment Share on other sites More sharing options...
Slacker_Sam. Posted April 24, 2012 Share Posted April 24, 2012 Repco has the tools. But I like to use a keen eye & a 3/8" drive long extension with insulation tape wrapped around it to pack it out a bit has never failed me yet. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 24, 2012 Share Posted April 24, 2012 Agree tool is over rated Quote Link to comment Share on other sites More sharing options...
Steelies Posted April 24, 2012 Share Posted April 24, 2012 get your fingers in the gaps round the sides of the clutch and you can feel if the plate is misaligned pretty easy. Quote Link to comment Share on other sites More sharing options...
Hemi Posted April 24, 2012 Share Posted April 24, 2012 i wish that worked with truck clutches Quote Link to comment Share on other sites More sharing options...
Steelies Posted April 24, 2012 Share Posted April 24, 2012 i wondered what happened to that clutch you posted in your destruction thread Quote Link to comment Share on other sites More sharing options...
Ogre Posted April 24, 2012 Share Posted April 24, 2012 ive fucked around using my eye, fingers, screw drivers and old input shafts, but DAMN the $16 tool from repco is worth its weight in gold IF USED CORRECTLY!!! Quote Link to comment Share on other sites More sharing options...
burrowssj Posted April 24, 2012 Author Share Posted April 24, 2012 wonder if its worth removing the engine ... have done in suzuki before it was a bitch lol Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 24, 2012 Share Posted April 24, 2012 What Steelies/Manu says is true - chuck the clutch etc on, make sure the clutch plate is the right way around (ie the shallow side faces the flywheel) do the cover bolts up till they are just nipped up and so you can still move the plate around. Put your fingers in the gaps between the pressure plate and the flywheel and you will feel where the clutch plate and pressure plate friction surface are - if you feel in all 3 gaps you will feel the gaps where the clutch plate sticks out past the pressure plate and is recessed in other gaps - move the plate around till you feel the same gap on all 3 access holes and you tighten up pressure plate bolts - recheck the gap and if it feels good you should be AOK to chuck in the gearbox... Quote Link to comment Share on other sites More sharing options...
burrowssj Posted April 24, 2012 Author Share Posted April 24, 2012 tomorrow will be interesting Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 24, 2012 Share Posted April 24, 2012 take your time and ask for help if you get lost - better to feel like a fool asking for help than looking like a fool for not.... Quote Link to comment Share on other sites More sharing options...
burrowssj Posted April 24, 2012 Author Share Posted April 24, 2012 im converting from column shift auto to column shift manual. It all came out pretty easy but theres a fair amount of work to be done putting it back in. Mainly linkage stuff, PITA but I'll get there Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 24, 2012 Share Posted April 24, 2012 good work - shouldn't be too hard if you have all the right parts Quote Link to comment Share on other sites More sharing options...
burrowssj Posted April 24, 2012 Author Share Posted April 24, 2012 I has a whole car of parts pretty much perfect situation. Get a complete conversion that I drove to my driveway and a bunch of other misc parts I was needing. I've dabbled in this before but not with the linkages so there is alil bit of fiddling to be done. I just like every other man enjoy a good fiddle tho.... Quote Link to comment Share on other sites More sharing options...
