Kevo Posted February 22, 2012 Share Posted February 22, 2012 cut up the arches and get some flares Quote Link to comment Share on other sites More sharing options...
Aaron Posted February 22, 2012 Author Share Posted February 22, 2012 Flares are like $150 on TM + dont have the tools to do it at home. Quote Link to comment Share on other sites More sharing options...
Kevo Posted February 22, 2012 Share Posted February 22, 2012 get some larger offset rims, or some much narrower tyres to clear the arches Quote Link to comment Share on other sites More sharing options...
phatt20 Posted February 22, 2012 Share Posted February 22, 2012 Slap some 175/50's on those hotwires! ! this will fix rubbing, have run the same wheel /tyre on a couple of starlets with no dramas. just the right amount of stretch. Quote Link to comment Share on other sites More sharing options...
Aaron Posted February 22, 2012 Author Share Posted February 22, 2012 this will fix rubbing, have run the same wheel /tyre on a couple of starlets with no dramas. just the right amount of stretch. **EDIT** So something like this? http://www.hyper.co.nz/drive/tyres/toyo ... 06/product Quote Link to comment Share on other sites More sharing options...
Sammy Posted February 22, 2012 Share Posted February 22, 2012 no need for bolt on flares just give the guards a bit more love Quote Link to comment Share on other sites More sharing options...
Aaron Posted February 25, 2012 Author Share Posted February 25, 2012 Ok, I have swapped the back tyres over to the front, seems to be working for now. Quote Link to comment Share on other sites More sharing options...
jtkp61 Posted April 5, 2012 Share Posted April 5, 2012 i dont reckon you should lower it,i think manual conversion / engine conversion, may be better shocks, but keep it stock...ish looking too many starlets are dumped, Thank you for your words of wisdom. I wasn't too keen on lowering it cause it seems quite cliche to do so. I will definitely need either new shocks/springs/tyres, because whenever I go over bumps in the road, the tyres scrape. Thoughts on any particular engine for the car? Cheers. Quote Link to comment Share on other sites More sharing options...
jtkp61 Posted April 5, 2012 Share Posted April 5, 2012 Hey man, nice car! Iv got one similar, I am lowering it on Cobra Superlows - got the ke70 shocks in the rear but looking for shorter inserts for the front, do you know what works? Thanks Quote Link to comment Share on other sites More sharing options...
Aaron Posted April 5, 2012 Author Share Posted April 5, 2012 Hey man, nice car!Iv got one similar, I am lowering it on Cobra Superlows - got the ke70 shocks in the rear but looking for shorter inserts for the front, do you know what works? Thanks Hey mate, not too sure what to recommend as I am quite n00b. Try posting in the Tech Talk section maybe. Quote Link to comment Share on other sites More sharing options...
Sambo Posted June 27, 2012 Share Posted June 27, 2012 You'll be hearing that ticking noise again very soon! I used to have to replace that gasket roughly every 3 months on my KE70. Take the manifold off, take it to a engine builders, have them machine the face flat and use double gaskets when putting it back on it'll be good as gold. Or don't even use double gaskets. Or buy an aftermarket manifold. Quote Link to comment Share on other sites More sharing options...
Ned Posted June 27, 2012 Share Posted June 27, 2012 Slam it! it's really cheap, just costs $30 for an angle grinder Quote Link to comment Share on other sites More sharing options...
Snoozin Posted June 27, 2012 Share Posted June 27, 2012 Hey man, nice car!Iv got one similar, I am lowering it on Cobra Superlows - got the ke70 shocks in the rear but looking for shorter inserts for the front, do you know what works? Thanks I have Mk1 Golf inserts in my shortened struts. RE: gasket, do what Sambo says EXCEPT take both the inlet and exhaust manifolds in and get them machined straight and to the same thickness. Quote Link to comment Share on other sites More sharing options...
Aaron Posted June 27, 2012 Author Share Posted June 27, 2012 Slam it! it's really cheap, just costs $30 for an angle grinder Haha nice. I was thinking maybe compressed springs, thoughts? And I hope to god that I dont get the ticking noise again. If I do, I will follow your instructions. Quote Link to comment Share on other sites More sharing options...
durty Posted June 27, 2012 Share Posted June 27, 2012 Compressed springs are shit. Go cuts first anyday Quote Link to comment Share on other sites More sharing options...
Aaron Posted June 27, 2012 Author Share Posted June 27, 2012 Sweeeeeeeeet. Quote Link to comment Share on other sites More sharing options...
Kevo Posted June 27, 2012 Share Posted June 27, 2012 Before you go cut your springs, I have 2 rears already cut that I wont be using. They may be a bit low but you can have them for free. Quote Link to comment Share on other sites More sharing options...
Snoozin Posted June 27, 2012 Share Posted June 27, 2012 Didn't I give you some cut springs? Or did I give them to someone else. Quote Link to comment Share on other sites More sharing options...
Aaron Posted June 27, 2012 Author Share Posted June 27, 2012 Cheers dudes. Snoozin: You gave them to Karl, who still needs to give them to me And cheers Kevo mate. Quote Link to comment Share on other sites More sharing options...
kpr Posted June 30, 2012 Share Posted June 30, 2012 pretty sure i still have some cut springs in my barrel of springs. they are from the front some fwd thing, nissan sunny maybe? anyway, they are harder than factory springs. also free, but... in whangarei /go to pick a part with a tape measure and find some harder springs that fit. then chop to length edit: they are a pair for the rear. Quote Link to comment Share on other sites More sharing options...
