Aaron Posted July 2, 2012 Author Share Posted July 2, 2012 Cheers all. But the car is rather fucked. Potential blown head gasket. Drove out to Otahuhu to pick up new tyres and was running quite hot, then it started cutting out and then went poop. Quote Link to comment Share on other sites More sharing options...
Aaron Posted July 9, 2012 Author Share Posted July 9, 2012 Anyone got any ideas on an upgraded radiator for a KP61? Or will I have to go with a stock one. Quote Link to comment Share on other sites More sharing options...
Ned Posted July 9, 2012 Share Posted July 9, 2012 Just use a stock one... It's a stock motor so stock cooling will be sweet. It's not like it's hot here in NZ or anything haha Quote Link to comment Share on other sites More sharing options...
Aaron Posted July 9, 2012 Author Share Posted July 9, 2012 Okey doke cheers. Quote Link to comment Share on other sites More sharing options...
Ned Posted July 9, 2012 Share Posted July 9, 2012 Stock is easiest. Just clean out the entire cooling system and should be like new again Quote Link to comment Share on other sites More sharing options...
Snoozin Posted July 9, 2012 Share Posted July 9, 2012 Go and get your radiator cleaned by a radiator shop if you have any concerns, it's not expensive and it'll probably blow your mind at how blocked it will be. Cheap "upgrade" for a neglected cooling system. Quote Link to comment Share on other sites More sharing options...
Aaron Posted July 9, 2012 Author Share Posted July 9, 2012 Cheers guys, will get onto that. Quote Link to comment Share on other sites More sharing options...
dylann Posted July 15, 2012 Share Posted July 15, 2012 RE: the fan. why dont you get one that bolts onto the water pump pulley and the shroud that covers the radiator? does the job for my 30, takes a bit to heat up but it doesnt worry me. Quote Link to comment Share on other sites More sharing options...
Aaron Posted July 15, 2012 Author Share Posted July 15, 2012 I would but there doesnt seem to be a big gap between that and the radiator. Also it looks like it would hit the pipe that goes from the raidator to the thermostat housing. Quote Link to comment Share on other sites More sharing options...
dylann Posted July 15, 2012 Share Posted July 15, 2012 ah right i didnt think about the gap, theyre not that big but the shroud may not fit .. ill go out and measure my fan for you now might help you out in some way EDIT Its 6x30cm. so its pretty small, and the shroud is 10cm deep from radiator to edge. Quote Link to comment Share on other sites More sharing options...
Aaron Posted July 15, 2012 Author Share Posted July 15, 2012 Cheers, the man. Quote Link to comment Share on other sites More sharing options...
kpr Posted July 15, 2012 Share Posted July 15, 2012 stock fan should work fine, the relay is under drivers kick panel with the fuses, its one of the round silver ones. there will be a temp switch on the water outlet somewhere. that controls the relay. if you unplug the sensor it should operate the relay and start fan. Quote Link to comment Share on other sites More sharing options...
Aaron Posted July 15, 2012 Author Share Posted July 15, 2012 Cheers mate, I tried taking the sensor off and plugging in each fan, but it still wouldnt go. Quote Link to comment Share on other sites More sharing options...
Kevo Posted July 15, 2012 Share Posted July 15, 2012 Where did you get the radiator from and how much? My car needs a new one as its cracked, and got 50% of the cooling fins missing. I have a working radiator fan motor you can borrow in case your spare one is stuffed as well. Quote Link to comment Share on other sites More sharing options...
Aaron Posted July 15, 2012 Author Share Posted July 15, 2012 Where did you get the radiator from and how much? My car needs a new one as its cracked, and got 50% of the cooling fins missing. I have a working radiator fan motor you can borrow in case your spare one is stuffed as well. PM'd cousin. Quote Link to comment Share on other sites More sharing options...
k2dori Posted July 19, 2012 Share Posted July 19, 2012 There's a pretty girl with cash ready to take this car off your hands right now come on! Quote Link to comment Share on other sites More sharing options...
Aaron Posted July 19, 2012 Author Share Posted July 19, 2012 3k and its yours. Quote Link to comment Share on other sites More sharing options...
dylann Posted July 21, 2012 Share Posted July 21, 2012 Like, did you end up having to get that pillar fixed? Quote Link to comment Share on other sites More sharing options...
Aaron Posted July 21, 2012 Author Share Posted July 21, 2012 Nope, went straight through. Quote Link to comment Share on other sites More sharing options...
SP450andLE Posted July 21, 2012 Share Posted July 21, 2012 Where'd you get your WoF? First Motors was closed the other day Need one on the Mini, ran out today Quote Link to comment Share on other sites More sharing options...
