M_C Posted July 27, 2015 Author Share Posted July 27, 2015 Please buy a Sierra wagon and transplant Cossie running gear into it. Its something Id love to do but no monies. An example of great ideas leaking into many peoples consciousness at the same time... I have a friend who has a Sierra wagon that used to have a YB turbo in it. Again dollars to put one back in was higher than benefit ratio so it currently as a 1UZ filling the hole. But he is tempted to put v6 in yoeddynz style and has been internet stalking your build. This post may even tempt him to reply, or shock horror, do some work on the car... Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted July 27, 2015 Share Posted July 27, 2015 Get him to start a thread!!! I like the Aerotina wagons and have always fancied one souped up to the right degree with a cossie front end in place. The cossie front end looks so choice. Quote Link to comment Share on other sites More sharing options...
Valiant Posted January 1, 2016 Share Posted January 1, 2016 I did a Cortina to w50 years ago. It ended up with a Cortina release bearing and cover with a Corona? clutch disc. I took it all along to BnT and went through their Toyota clutch plates until I found one the right spline and diameter. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted January 14, 2016 Share Posted January 14, 2016 flip those are some nice extractors! 2 Quote Link to comment Share on other sites More sharing options...
bryck Posted February 26, 2016 Share Posted February 26, 2016 Max, all the best for your trip. Hope it's all smooth sailing and look forward to seeing you back in a few years. Quote Link to comment Share on other sites More sharing options...
escort74 Posted February 27, 2016 Share Posted February 27, 2016 will keep an eye on your travel blog mate , good to see the esky is all safe and sound in storage almost time !!!! Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted February 13, 2018 Share Posted February 13, 2018 Welcome Home! Look forward to the updates 1 Quote Link to comment Share on other sites More sharing options...
Kiwibirdman Posted May 5, 2020 Share Posted May 5, 2020 For the cam timing, the method of both valves open the same amount on TDC is the tried and true way of doing cams of unknown origin. It should be close enough to get you running, you can always play round with the cam timing once it is going. Pretty easy to do on a Pinto and no chance of bouncing valves off pistons. 2 Quote Link to comment Share on other sites More sharing options...
M_C Posted May 5, 2020 Author Share Posted May 5, 2020 6 hours ago, Kiwibirdman said: For the cam timing, the method of both valves open the same amount on TDC is the tried and true way of doing cams of unknown origin. It should be close enough to get you running, you can always play round with the cam timing once it is going. Pretty easy to do on a Pinto and no chance of bouncing valves off pistons. Thanks! I put this up in the tech talk as well and kpr suggested slightly more lift on the inlet at TDC. 3.86mm inlet lift is 3.45 exhaust lift and 103 degrees advanced. This is pretty close to same lift which is 105 degrees. The head has been shaved a small amount and there is more lift than standard so possibly interference now. I don’t want to find out the hard way... Quote Link to comment Share on other sites More sharing options...
Nominal Posted June 21, 2021 Share Posted June 21, 2021 Had to walk back through the thread to see the last time it was running - 2013? No wonder you had a big smile when it started up - well done. Classy return spring setup too 2 Quote Link to comment Share on other sites More sharing options...
M_C Posted June 21, 2021 Author Share Posted June 21, 2021 After blowing the old V6 up at Hampton ~2013 I did get distracted when shopping for an engine and buying a nice turboed one that came in a car -the Geisha. And then numerous other escorts, and a 2 year sabbatical on a boat with the family, and move to new town etc etc etc... Yeah, its been far too long. Scary how young the kids look, even just at the top of the current page! Let put it this way the kids were 7 and 5 the last time I drove her and this month I bought the kids their own race car. If they bin the Puglet I will be sad, but no where near as sad as if they bin Felicity the escort. And for a front tugger its so much fun to drive. (Return spring is on the long list ) 4 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted June 24, 2021 Share Posted June 24, 2021 So cool hearing a new engine start up. I laughed when I read "had dissy 180 degrees out" as I too have done that a few times and never learn 1 Quote Link to comment Share on other sites More sharing options...
