xsspeed Posted February 1, 2012 Share Posted February 1, 2012 ^ In light of this maybe not then Quote Link to comment Share on other sites More sharing options...
mikuni Posted February 1, 2012 Share Posted February 1, 2012 From my Vectra build thread - these are from the front of an EF I think, but the rear are quite similar They came compressed in the shocks, which introduces a small issue that anyone who has undone coil over shocks before will understand. Now getting the springs out can be quite dangerous, so it is very important to use the correct tool for the job. Once I had the shocks secure in my custom press, I loosened the top bolt and out the springs came. All limbs intact. I couldn't get the hooks of the compressors between the spring coils and even if you could, they would sit to close to everything anyway. Not to mention that the radius of the springs is much tighter than normal compressors also. Ones like this would probably be ok But these ones yeah/nah Quote Link to comment Share on other sites More sharing options...
xsspeed Posted February 1, 2012 Share Posted February 1, 2012 Why? Diameter of springs too small to fit inside the 'perches' of the compressors? Quote Link to comment Share on other sites More sharing options...
Toucan Posted February 1, 2012 Share Posted February 1, 2012 Yea, those cast silver ones are horrible on honda stuff. I just sat on the tophat an loosened nut with impact gun. Lifts you up a bit/got a hole in my favourite shorts, but so beats fiddly spring compressors. Quote Link to comment Share on other sites More sharing options...
mikuni Posted February 1, 2012 Share Posted February 1, 2012 Why? Diameter of springs too small to fit inside the 'perches' of the compressors? Yeah pretty much. I couldn't get the hooks of the compressors between the spring coils and even if you could, they would sit to close to everything anyway. Not to mention that the radius of the springs is much tighter than normal compressors also. Quote Link to comment Share on other sites More sharing options...
xsspeed Posted February 1, 2012 Share Posted February 1, 2012 My bad I looked at photos and didn't read your text Quote Link to comment Share on other sites More sharing options...
phr34kr Posted February 1, 2012 Share Posted February 1, 2012 Have a set of these: I know they Just fit on crx/civic springs, due to them only having the single hook on one end, if you want to borrow them pm me Im in Epsom. Quote Link to comment Share on other sites More sharing options...
chees- Posted February 1, 2012 Author Share Posted February 1, 2012 shit didn't even think about that, steve they're out of the car so we may aswell give them a shot? give me a txt when your free thanks tara for the offer and for the info guys phr34kr might have to take you up on that if steve's don't work Quote Link to comment Share on other sites More sharing options...
chees- Posted February 2, 2012 Author Share Posted February 2, 2012 fail, no petrol cap (sorted) right front bumper needs securing (sorting) left stop light? (park light? think that must be it) excessive play l/r upper suspension tailpipes rotten excessive play l/f ball joint ground clearance below 100mm (sorting) looks like i'm gonna be rolling stock for awhile, oh well atleast it'll be comfortable again Quote Link to comment Share on other sites More sharing options...
DB8-TypeR Posted February 2, 2012 Share Posted February 2, 2012 Honestly if you have such short springs in there you can just whip the tophats right off. Of course undo the nut slowly but the springs should become uncaptive before the nut comes off. Unless of course your shocks have been shortened Quote Link to comment Share on other sites More sharing options...
chees- Posted February 2, 2012 Author Share Posted February 2, 2012 i believe my shocks have cause i pulled them off and compared to the originals they're tiny, no way i can use the original shocks with these springs, will take photos tomorow Quote Link to comment Share on other sites More sharing options...
DB8-TypeR Posted February 3, 2012 Share Posted February 3, 2012 Ahh yep I thought they would be, as there is no way it could possibly be that low with stock shocks and just lowering springs Quote Link to comment Share on other sites More sharing options...
chees- Posted February 17, 2012 Author Share Posted February 17, 2012 lame update, car is now 4wd high. balljoint and bushings done. just need to sort exhaust (anyone know if its legal for an exhaust to go straight out the side behind rear wheels?) pics of suspension vs suspension Quote Link to comment Share on other sites More sharing options...
xsspeed Posted February 17, 2012 Share Posted February 17, 2012 Like I said on wednesday, grab that part number off the kings and it should be able to tell you a bit about it, including what vehicle its from - might give you a clue what the shocks are Quote Link to comment Share on other sites More sharing options...
chees- Posted February 17, 2012 Author Share Posted February 17, 2012 Like I said on wednesday, grab that part number off the kings and it should be able to tell you a bit about it, including what vehicle its from - might give you a clue what the shocks are eg civic superlows, interesting Quote Link to comment Share on other sites More sharing options...
xsspeed Posted February 17, 2012 Share Posted February 17, 2012 this the doc you found? http://svc097.wic026v.server-web.com/ca ... 040203.pdf Quote Link to comment Share on other sites More sharing options...
xsspeed Posted February 17, 2012 Share Posted February 17, 2012 Looks like they are prograssive according to that Quote Link to comment Share on other sites More sharing options...
chees- Posted February 17, 2012 Author Share Posted February 17, 2012 yep they are, so how do i know which ends progressive? bottom end tapers in so i assume that end? Quote Link to comment Share on other sites More sharing options...
xsspeed Posted February 17, 2012 Share Posted February 17, 2012 pretty sure its the end with more/tighter coils BUT WAIT FOR SOMEONE TO CONFIRM THAT PLZ Quote Link to comment Share on other sites More sharing options...
xsspeed Posted February 17, 2012 Share Posted February 17, 2012 If you could get them out of the shock, it'd be the end thats easier to squish by hand, so if one was to go as far as cutting, they would want to cut the stiff end Quote Link to comment Share on other sites More sharing options...
