mikey Posted November 15, 2011 Share Posted November 15, 2011 This is a good fred. Esp liked reading about the fab work on the retrorides site. I've just been stripping paint off my bonnet, there was some real light rust underneath which I've wirewheeled, I'm going to pa10, but should I use rust converter first? Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 15, 2011 Share Posted November 15, 2011 i would Quote Link to comment Share on other sites More sharing options...
andy Posted November 15, 2011 Share Posted November 15, 2011 This is a good fred. Esp liked reading about the fab work on the retrorides site.I've just been stripping paint off my bonnet, there was some real light rust underneath which I've wirewheeled, I'm going to pa10, but should I use rust converter first? neither rust converter or PA10 will get rid of the rust. It will just back and wreck your paint. Have a look at this thread and do this if you only want to do it once. You cant get the navel gel they use in NZ so can use jenolite. http://www.metalmeet.com/forum/showthre ... +willys%22 Quote Link to comment Share on other sites More sharing options...
mikey Posted November 15, 2011 Share Posted November 15, 2011 This is a good fred. Esp liked reading about the fab work on the retrorides site.I've just been stripping paint off my bonnet, there was some real light rust underneath which I've wirewheeled, I'm going to pa10, but should I use rust converter first? neither rust converter or PA10 will get rid of the rust. It will just back and wreck your paint. Have a look at this thread and do this if you only want to do it once. You cant get the navel gel they use in NZ so can use jenolite. http://www.metalmeet.com/forum/showthre ... +willys%22 So rust converter is different from Naval Jelly? Sounds like Naval Jelly is just phosphoric acid. I kinda figured most rust converters had some sort of acid in them but I'm going to Bunnings today so will check it out and make sure they do. Quote Link to comment Share on other sites More sharing options...
andy Posted November 16, 2011 Share Posted November 16, 2011 navel jelly uses phosphoric acid but it is in a jelly like solution whereas jenolite etc are a light liquid. I tried to find a way of adding something to make the jenolite hold better as this would be ideal for vertical surfaces. I guy at the paint shop advised recently that all phosphoric acid products were being taken off the market. Quote Link to comment Share on other sites More sharing options...
tortron Posted November 16, 2011 Share Posted November 16, 2011 just painting it will be fine hell my truck was painted with house paint 10 years ago and its still stuck on like shit to a blanket Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 17, 2011 Share Posted November 17, 2011 i dont like how you have to wash that jelly stuff of with 'warm soapy water' soap=salt? Quote Link to comment Share on other sites More sharing options...
andy Posted November 17, 2011 Share Posted November 17, 2011 I dont either. I use meths. It neutralises the acid and then flashes off. Then a quick rub with keyphos and your bare metal is good for 8 - 12 months. Quote Link to comment Share on other sites More sharing options...
LS 2 THE DEEE Posted November 17, 2011 Share Posted November 17, 2011 Can anyone in this thread recommend someone/panelbeater on the north shore to chop out some rust and weld nice fresh metal in its place? wont need any finishing just patch it, give it a grind and maybe a splash of etch primer Quote Link to comment Share on other sites More sharing options...
Taistorm Posted November 17, 2011 Share Posted November 17, 2011 Can anyone in this thread recommend someone/panelbeater on the north shore to chop out some rust and weld nice fresh metal in its place?wont need any finishing just patch it, give it a grind and maybe a splash of etch primer Theres an old Bloke called Frank who works from home and lives a bit behind the Pare prison. He's been our family panelbeater for a long time and he does a lot of truck work as well. Can contact him on 4139572 Quote Link to comment Share on other sites More sharing options...
LS 2 THE DEEE Posted November 17, 2011 Share Posted November 17, 2011 thats perfect i live at the start of pare rd so a no wof or reg drive that far is ideal......cheers mate! Quote Link to comment Share on other sites More sharing options...
mekemelorry Posted December 28, 2012 Share Posted December 28, 2012 Anyone know of a similar product to POR15? But cheaper? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted December 28, 2012 Share Posted December 28, 2012 PA10 Quote Link to comment Share on other sites More sharing options...
