Increasing stiffness of leaf springs
Mikewazowski
Okay, so I've lowered my 180B (610) wagon around 90 mm and I'm now having a few issues with my rear driveshaft flange (by the diff) connecting with the floor underneath the rear seat. It's lowered using 50 mm lowering blocks and the main leaves have had the eyes reversed (40 mm).
It looks like I'm possibly going to have to raise the rear a little (10mm?) and/or cut and raise the floor.
I'm thinking I'll need to stiffen the rear suspension to stop the floor coming down and contacting anything when I put stuff in the back/people hop in the car.
What is the best way to go about this?
Would I want to get and extra leaf added to the pack, or could I potentially use some of the coil-over shocks that I see listed for leaf-sprung cars that carry loads?
Keen to hear people's thoughts since I'm quite new to leaf springs.
I'm not sure whether an overload spring would help in my case since I don't think the spring flattens out completely before the floor makes contact. I was under the impression that an overload spring would only affect the spring rate once the spring pack had flattened out and touched the overload spring along its length. It is very possible that I'm not sure what I'm talking about though.
You can pull the springs apart and re-arch them yourself if you want to.
A couple of ways:
Easy
Hard: Put the leaf down on a couple of steel blocks with a gap between them, and smack with a heavy hammer on the leaf above the gap.
Work along the spring from front to back. Make sure you mark out the starting curve with chalk or something on the floor first.
I need to do the rear leafs in my Holden, getting saggy after 40 years. One day!
Thanks for all the feedback. :D
short story is if you want it that low get springs reset and maybe added leaf . or 'massage' the floor . or cut section of floor out and make a new tunnel that will require cert though .
I'm not really sure why I'd need to reset the springs since it is already low enough, or is that to compensate for the extra height gained by adding a leaf. On that note, why does adding a leaf raise the car?
My front crossmember is around 80 - 85 mm ground clearance so I'm going to need a cert at this height regardless. I'd say no matter what I do I'm probably going to need to either massage the floor, or more likely, cut the floor and have a new section welded in. If I can do this and still run my original rear seat then that shouldn't be an issue.
Cheers
Sweet. That makes sense.
So it looks as if adding another leaf and getting the springs reset (again) may well be my next port of call. Hopefully combining this with new shocks and tunnel mods should result in my driveshaft not clipping the floor. Which would be an improvement :lol:
ye that, and/or possibly jam some bump stops in so the diff/dshaft cant hit the floor?
Yeah the bumpstop above the diff is just (a couple of mm) shy of connecting with the diff as it sits currently. The dshaft flange only hits on the corners as it rotates so I wouldn't need much clearance and then the bumpstop would actually stop any metal to metal contact as far as I can tell.
Yeah I think that + new shocks (which I need anyway) might be my first port of call. Although I'm picking that 5 mm travel until it hits the bumpstop is probably not going to fly, especially since it'll sit on the bumpstop with 3 people in the car I'm pretty sure.
Tempting to raise it by 15 - 20 mm, not require a cert and most of the issues will probably disappear...but it just looks so good :rolleyes::lol:
