13" 3 Piece Wheels
bugn8r
That's my main problem. I don't know what you would use. I had hoped someone would know a workshop that could do it cheaper I guess, I just wasn't sure if workshops would have a tool that would work. Maybe chill out because I was just asking, no harm in trying to save some money.
You need a hex bit socket of the right size. They work best when accompanied by a rattle gun/impact driver to shock the nut off.
If you can, use a small power bar place the hex bit into the hole then get a socket or spanner onto the nut that lives on the inside of the wheel. Undoing the nut is easier than cranking on the allen head and you are less likely to round it off. If you can use a small rattle gun on the nut it makes life a lot easier (cordless impact drivers or small impact wrenches work).
Give it a go with a hex bit and a socket on the back and if that doesn't work, take it to elite/an engineer.
