rebel county Posted April 20, 2011 Share Posted April 20, 2011 I want to paint my dashboard to dark grey, currently it's shitty plastic brown. What products should I use to paint it? What prep work should I do? Cheers David Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 20, 2011 Share Posted April 20, 2011 Vinyl die - a good rub down with a cleaning spirit should be enough.. Quote Link to comment Share on other sites More sharing options...
rebel county Posted April 20, 2011 Author Share Posted April 20, 2011 Vinyl die - a good rub down with a cleaning spirit should be enough.. Thanks, I should be able to get that from Repco or Supercheap Auto? Is it in a spray can or does it have to be brushed on? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 20, 2011 Share Posted April 20, 2011 spray can Quote Link to comment Share on other sites More sharing options...
rebel county Posted April 20, 2011 Author Share Posted April 20, 2011 Daaaycent, thanks KK-Kolonel! Quote Link to comment Share on other sites More sharing options...
xsspeed Posted April 20, 2011 Share Posted April 20, 2011 Suggest getting a spare bit of dash or something and doing a test - IMO that brown is sweet Quote Link to comment Share on other sites More sharing options...
rebel county Posted April 20, 2011 Author Share Posted April 20, 2011 Suggest getting a spare bit of dash or something and doing a test - IMO that brown is sweet tis not my cup of tae at all Quote Link to comment Share on other sites More sharing options...
JasonK Posted April 21, 2011 Share Posted April 21, 2011 Vinyl die - a good rub down with a cleaning spirit should be enough.. looks like a hard (non porous) plastic to me, if so vinyl die won't soak in, however I may be wrong. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted April 21, 2011 Share Posted April 21, 2011 can get grey bumper paint mixed up at friendly local paint store but will be matt finish Quote Link to comment Share on other sites More sharing options...
kicker Posted April 21, 2011 Share Posted April 21, 2011 I used the spray on the dash of an old holden I used to have, worked good, the fumes are pretty strong though so make sure you have good ventilation Quote Link to comment Share on other sites More sharing options...
rebel county Posted April 21, 2011 Author Share Posted April 21, 2011 that looks like a grand job. i presume you took out the dashboard? Quote Link to comment Share on other sites More sharing options...
kicker Posted April 21, 2011 Share Posted April 21, 2011 Yeah pulled everything out, did the door cards, arm rests and A-pillar trim too Quote Link to comment Share on other sites More sharing options...
Mike-e Posted April 21, 2011 Share Posted April 21, 2011 you will miss shitty plastic brown. tbh I would buy shitty plastic brown if they made it in cans Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted April 22, 2011 Share Posted April 22, 2011 you will miss shitty plastic brown. tbh I would buy shitty plastic brown if they made it in cans QFT Also, Supercheap's 3M Vinyl paint (not dye) is ideal for painting plastic trim and dashboards. A workmate of mine used plenty of it when restoring the interior of His Porsche. Came up mint. As suggested earlier, vinyl dye may not in my opinion penetrate far enough into the plastic to produce a consistent result. Having used the paint and seen the final result, I'd recommend it for this job. Quote Link to comment Share on other sites More sharing options...
rebel county Posted April 22, 2011 Author Share Posted April 22, 2011 you will miss shitty plastic brown. tbh I would buy shitty plastic brown if they made it in cans QFT Also, Supercheap's 3M Vinyl paint (not dye) is ideal for painting plastic trim and dashboards. A workmate of mine used plenty of it when restoring the interior of His Porsche. Came up mint. As suggested earlier, vinyl dye may not in my opinion penetrate far enough into the plastic to produce a consistent result. Having used the paint and seen the final result, I'd recommend it for this job. have painted the door cards dark grey (Supercheap's 3M Vinyl paint), gave out mighty! defo won't be missing that shitty brown!!! the dash is tomorrow... Quote Link to comment Share on other sites More sharing options...
