Taistorm Posted January 11, 2011 Share Posted January 11, 2011 Hi there, My chevette started playing up today when i took it for a drive down to the gasy. The cars pretty much been off the road for the last 4 months. I took it for a drive from browns bay to whangaparoa a week or so ago twice and it was running mint, then all of a sudden today when i went to chuck some gas in, afterwards the engine started to slowly decelerate and jerk/jump as if it was running outta gas. trying to figure out whats gone wrong... Its the little 1256cc and all ive done to it is switch to a 28/36dcd carb (rebuilt to suit said engine), new plugs, leads dizzy cap and rotor + oil change and what not. You guys got any ideas bout what might be wrong? I checked for vacuum leaks but it was sweet and the timings spot on as I changed the belt about a 2 months ago and timed it perfect. All helps appreciated! Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted January 11, 2011 Share Posted January 11, 2011 Check the fuel filter Quote Link to comment Share on other sites More sharing options...
Taistorm Posted January 11, 2011 Author Share Posted January 11, 2011 Ok sweet, will check it out. Thanks Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 11, 2011 Share Posted January 11, 2011 yeah sounds like fuel filter to me also. If its been siting for a while, and also being of the britsh origin, then there is probabaly all sorts of shit in the tank. Also you mentioned it was not till after you added fuel..... so this backs up that something might be in your tank, blocking up your fuel filter. option two is that there could be water in your tank/ carb/ fuel Quote Link to comment Share on other sites More sharing options...
jakesae101 Posted January 11, 2011 Share Posted January 11, 2011 if its water in the carbs try taking the air cleaner off and stick your hand over it till it almost dies a few times and that should clear the water out of the carbs Quote Link to comment Share on other sites More sharing options...
KKtrips Posted January 12, 2011 Share Posted January 12, 2011 If you have water in your tank - make sure you have the tank halfish full (about 20-30litres in there) and chuck in a litre of methylated spirits - you'll smell like you are burning homeless bums for a week but it'll mop up any water in your tank.. Quote Link to comment Share on other sites More sharing options...
rxsumo Posted January 14, 2011 Share Posted January 14, 2011 Where is the fuel filter located? My RX3 gets an issue with crap coming off the fuel lines, causing random jets to block....mainly because the fuel filter location is at the rear of the car. Was the float bowl in the Weber clean before you put it in the car? Is the accelerator pump working on the carbie? Quote Link to comment Share on other sites More sharing options...
Taistorm Posted January 14, 2011 Author Share Posted January 14, 2011 Im going to buy a new fuel filter tomorrow to replace the current one and see if that makes a difference. The car was 'juttering' a little before putting some gas in but it wasnt til after a minute of driving from the servo that it started to play up badly. When I park the car up the car idles smoothly for a while then slowly begins to ) When I park the car up the car idles smoothly for a while then slowly begins to accelerate(Edit:) decelerate. The guys on the gm-t forum suggested it could easily be a distributor problem aswell (loose connection), so i'll also check that this weekend hopefully. Quote Link to comment Share on other sites More sharing options...
efp0wa Posted January 16, 2011 Share Posted January 16, 2011 Maybe some shit in the fuel tank or lines managed to make its way past the fuel filter and into the carb jetting Quote Link to comment Share on other sites More sharing options...
mjrstar Posted January 16, 2011 Share Posted January 16, 2011 I had similar issues from a bad batch of gas from a servo.. Car would idle fine but as soon as you put your foot down engine would shudder and vibrate.. Draining all the fuel and starting afresh saw it come right pretty quick... Quote Link to comment Share on other sites More sharing options...
Taistorm Posted January 17, 2011 Author Share Posted January 17, 2011 Didnt get round to doing anything about this problem on the weekend but I did score a mint hexican blanket from kumeu Should have it sorted by the end of this week, ready for the nostalgic/oldschool meet on sat. Quote Link to comment Share on other sites More sharing options...
