mjrstar Posted September 4, 2010 Share Posted September 4, 2010 Only hard bit is if the axle is stuck, sometimes they fall out, sometimes you want to burn your car to the ground because its so stuck he speaks the truth, much gas-axe action to try and get my hilux diff apart. price wise i didn't think the bearings were too costly maybe 110 for the pair from partsmaster. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted September 4, 2010 Share Posted September 4, 2010 he's not doing the bearings Russell - just the axle seals.. Oh right! should do bearings at same time In that case yeah that seal bit is super easy once axles out. Quote Link to comment Share on other sites More sharing options...
EFI_LC Posted September 4, 2010 Share Posted September 4, 2010 I tried to offer a simple no swear way of doing it... I did mine and they were original from 80's and even though it took a bit of effort they were a piece of piss and used gravity to remove em and the pipe made sure they went back in even. Quote Link to comment Share on other sites More sharing options...
kpr Posted September 5, 2010 Share Posted September 5, 2010 all the hilux/hiace ones ive done have come out piss easy. nothing really for them to jam up on. bearings, now they can be a dick. Quote Link to comment Share on other sites More sharing options...
zep Posted September 7, 2010 Author Share Posted September 7, 2010 BTW, does any one know the part number for this seal, and the o-ring too? I rang up part master and they had no idea. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 7, 2010 Share Posted September 7, 2010 The part number (or dimensions at least) for the seal should be written on the front face Measure the diameter of the o ring profile then the diameter of the slot where it sits on the housing - that should give you the dimensions for the o ring.. Or SKF/Saeco Bearings should have the info for the diff or be able to match to a sample/dimensions you give.. Quote Link to comment Share on other sites More sharing options...
kpr Posted September 8, 2010 Share Posted September 8, 2010 i got a spare seal down in the shed. will go see if i can find some numbers on it soon.. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted September 8, 2010 Share Posted September 8, 2010 BNT said there were quite a few diff models when i ordered mine from memory. just took my axle down there and they worked out out. Quote Link to comment Share on other sites More sharing options...
kpr Posted September 8, 2010 Share Posted September 8, 2010 nok ah2853g <- on the seal 90310-50006 <- toyota part number Quote Link to comment Share on other sites More sharing options...
zep Posted September 8, 2010 Author Share Posted September 8, 2010 Cheers dude! Quote Link to comment Share on other sites More sharing options...
Josh Posted October 20, 2010 Share Posted October 20, 2010 Just did mine not long ago, that were bloody expensive! Found my hilux diff leaking also after dragging the other weekend, have the axle out, is it just that small black seal the only one to replace on the inside of the bearing there? First time I've done this.. Never had an outer o ring seal, so will chuck one of those back in to. Also this breather business, where is that located, top of diff somewhere I assume? I didn't realise there was one till now and can't be to hard to find no doubt anyway. Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 20, 2010 Share Posted October 20, 2010 Dont quite know what your asking, but to stop your axle leaking you just do something like this. Then tap a new shaft seal in nice and square Quote Link to comment Share on other sites More sharing options...
kpr Posted October 20, 2010 Share Posted October 20, 2010 yeh just the seal in the housing, the whole gold coloured part(in above pic) comes out. wouldn't worry about the oring too much if you dont have one. just use some gasket goo. breather is up top above the head. little spring loaded metal cap thing Quote Link to comment Share on other sites More sharing options...
Josh Posted October 20, 2010 Share Posted October 20, 2010 Excellent, cheers, shall get part and attack tomorrow night. Do all the hilux diffs have breathers? Quote Link to comment Share on other sites More sharing options...
