ryanfels Posted December 18, 2012 Share Posted December 18, 2012 I think my custom made surge tank in my ke70 cost me about $200 in total with the extra pump and lines. Just FYI Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted December 18, 2012 Share Posted December 18, 2012 hmmm fair enough Well, so far this setup has cost me $50 haha Also where I would want the surge tank is where I am now planning on putting my battery Quote Link to comment Share on other sites More sharing options...
ryanfels Posted December 18, 2012 Share Posted December 18, 2012 I hung mine between the tank and rear valance which kept it well out of the way of anything Just ask Ned for $200, hes got money to burn Quote Link to comment Share on other sites More sharing options...
KKtrips Posted December 18, 2012 Share Posted December 18, 2012 Just a quick question. What size surge tank is considered adequate ie what is the smallest I can get away with. Also Ryan is this the way your fuel system is plumbed - it's exactly how I imagine I want to do it for my 1UZ conversion.. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted December 18, 2012 Share Posted December 18, 2012 think you should run a return from the surge tank to the fuel tank also, Edit, but then again, i guess if the LP pump is rated to 4psi or whatever, then its not going to pressureise the surge tank However a return line would help with breathing Quote Link to comment Share on other sites More sharing options...
ryanfels Posted December 18, 2012 Share Posted December 18, 2012 Just a quick question. What size surge tank is considered adequate ie what is the smallest I can get away with. Also Ryan is this the way your fuel system is plumbed - it's exactly how I imagine I want to do it for my 1UZ conversion.. Pretty much except it had a return to the tank aswell Quote Link to comment Share on other sites More sharing options...
KKtrips Posted December 18, 2012 Share Posted December 18, 2012 This is so the wrong thread to be asking this so I'll split and move it later on but is there any reason why I can't have the fuel return from the surge tank T-ing into the fuel filler breather? I know I should just pull the tank out and do it properly but I just hate the idea of drilling a hole in my tank and having possible leaks. I know I'm an idiot but it's just one of those things. Quote Link to comment Share on other sites More sharing options...
Spencer Posted December 18, 2012 Share Posted December 18, 2012 Lol at you guys suggesting things when he's this balls deep with a cut up tank, Seedy had a whole thread about this haha The thread concluded that he would be fine with an external pump and no baffles, even with a low tank in the wags. But Al insisted he wanted to do burnouts with $10 gas in it so needed something better. A surge tank is all good, but in tank is by far the tidier way to do it on a car like this and Al's on the right track, just don't think he's got the best in tank setup to transplant into his, plus he's in a rush Quote Link to comment Share on other sites More sharing options...
Spencer Posted December 18, 2012 Share Posted December 18, 2012 KK you could use the breather yes, do it properly though. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted December 18, 2012 Share Posted December 18, 2012 This is so the wrong thread to be asking this so I'll split and move it later on but is there any reason why I can't have the fuel return from the surge tank T-ing into the fuel filler breather? I know I should just pull the tank out and do it properly but I just hate the idea of drilling a hole in my tank and having possible leaks. I know I'm an idiot but it's just one of those things. Thats exactly where my return went to Quote Link to comment Share on other sites More sharing options...
KKtrips Posted December 18, 2012 Share Posted December 18, 2012 All good info. Yeah sorry about the too late questions disguised as suggestions. One last question. What is the minimum volume surge tank I could get away with? As small as 100ml? Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted December 19, 2012 Share Posted December 19, 2012 Hey Dude! I used a 2jz in tank pump in my 1200 wagon fuel tank. I cut a big hole in the top. welded a peice of 4 inch pipe into the tank all the way to the bottom with a couple 10mm holes at the bottom. then i welded a peice of 3mm plate to top of the tank so that the fuel pump unit could sit into the hole and bolt up to the tank sealing the gap. ta da all working Also used a fuel tank sealer once all welding was done to fill any pin holes. worked a treat Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted December 19, 2012 Share Posted December 19, 2012 haha I'm pretty happy with how my setup has transpired, just a noob learning as I go as I have never really done a tank job before. its hard to know what to use till you cut up your original tank, and i also didnt want to spend forever goig round pick a part trying to find the perfect unit. So with everything i have now, its going to work just fine, and cheap. thats how i like it i have however run return lines into breather hoses before no problems Quote Link to comment Share on other sites More sharing options...
Mr dori Posted December 24, 2012 Share Posted December 24, 2012 Hey bro, ive got bit of 2jz stuff lying round if you need. Map sensor and stuff, head/ covers etc etc Quote Link to comment Share on other sites More sharing options...
Steelies Posted January 9, 2013 Share Posted January 9, 2013 anywhere in welly i can have a hunt for ecu? Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 9, 2013 Share Posted January 9, 2013 na, not that I can think of. Might make so calls to peoples I know down there. Kinda decided I will maybe just get the link swapped but i have no had any luck getting a reply from the link guys. think they might be on extended break So most likeely wont get it back in time anyways. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted January 9, 2013 Share Posted January 9, 2013 1J or 2J? I can't remember and cbf checking. I have a 1J sitting around but dunno if there's an ECU with it. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 9, 2013 Share Posted January 9, 2013 2j I dont know if they are the same? Also need a map sensor to suit, a Drive belt tensioner, and a waterpump pully lol Quote Link to comment Share on other sites More sharing options...
ryanfels Posted January 9, 2013 Share Posted January 9, 2013 The pully might be the tricky part. You may have to got aftermarket. Is there anything on yahoo? Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 9, 2013 Share Posted January 9, 2013 oh....... why will it be trickey??? Quote Link to comment Share on other sites More sharing options...
